fit 2 units and combine the ducts 2 into 1.
I thought that, is it okay with two motors pushing to the same duct.
Both showers may be used at the same time
can't see a problem as long as there's no back flow from one to the other. good quality fans should be OK. some other members may have better knowledge here than i have.
The link was for a double one but had only one light fitting, the other was a basic fan with white plastic surround
Oh I see, you are wanting a shower light vent to replace the white grille with ? you could contact manrose and ask if they sell them separately. Both shower lights will come on at once of course unless the lights operate independently of the fan.....Not a great solution
I'd fit 2 seperate fans/lights then there is no chance of venting from one room to the other. Also better in the long run for fault finding etc.
JTWIDI
Reactions: 1 person
If you can arrange it, two entirely separate extraction systems would be best. Is this not possible?
Edt: Ha! I see Murdoch has the same thought.
ahh, didnt think about them both coming on, and for fault finding. Was trying to find a simple solution with aq double one but will go with two individual ones. can I Tee them to the same duct?
You could but you'd still be vulnerable to odours / steam from one room going to the other!
you can fit backdraft units in the ducts.
Twin Shower extractor fan with light
Plumbstar Tom,
Plumbstar Tom,
