Discuss Two way light switch Hall /Landing 2 vs 3 core wiring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I was going to post, but then thought what the hell, the guys have got this covered, i'll go back to the jokes thread.:teeth_smile:
If it's a 2 way switch, (ie there's another switch which controls the same light) it sounds like he's used the earth as a live core, which IMO is unacceptable because the earth has a smaller CSA than the other cores and it relies on the outer sheath for electrical insulation when it's only intended to provide mechanical protection.
It might be worth getting someone to have a look at it.
It's not 3 core, it T&E, so no brown blue or green and yellow, just black and red. I think the E has been made into part of the circuit though so there's a third red.
Just wondering if you have metal switches that are not earthed the hole you are digging is getting deeper
Reply to Two way light switch Hall /Landing 2 vs 3 core wiring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi all, currently doing a job at a house where there are 3 switches In the hallway to control the hall lights. All 1 gang switches, one at...
Hi brains trust, I am aware of typical wiring and legalities hence the questions. Looking for a wiring diagram to allow me to use a dual switch...
Suggestions / solutions please anyone? I have a 2 way switch, Hall and Landing, power being fed on Landing. When the switch is turned on, the...
