Search for tools and product advice,
Discuss UFH internet connection ? in the Computer and Networking Forum area at ElectriciansForums.net
steve32
Not sure if this is the correct section ?
I am currently installing cables for a wet underfloor heating system, stat cables and control wires to the boilers and tanks. Connecting all this up is not a problem, the issue that has accurred is the the builder has told me the client would like to control the heating and hot water from his I pad via the wi-fi connection. The client is already having a a lutron lighting system installed that can be controlled by the pad.
My question is, is there a switcher/control box i can use to connect the heating system the internet ???
Hope that all makes sense ?
Reply to UFH internet connection ? in the Computer and Networking Forum area at ElectriciansForums.net
Hi all, I've noticed that my UFH pump is not always turning on as soon as the stat & valve calls for heat. This results in hot water passing...
What’s the best setup for a system that has a heating system with existing radiators but a wet underfloor heating system is being added to a new...
Hi. I'm installing a wet underfloor heating system in my own house. What would you recommend as the best smart control system? I can hardwire...
I've always thought I was quite good a wiring heating systems, I can do Y plan, S plan, UFH set ups, "normal" thermal stores etc, you name it and...
I have a loose wire underfloor heating system I am installing for a client ideally they would like the UFH to continue into the down stairs loo...
