Discuss UH3 to boiler connection help please... in the UK Electrical Forum area at ElectriciansForums.net
Colin33
I am wiring a UH3 to a Grant Vortex Pro internal combi. The heating system is underfloor only, no rads, and no DHW storage. I have stats and a time clock wired into the UH3. I have a supply to the boiler.
My question is, where do i terminate the UH3's 'boiler in/out' wires within the boiler itself? Boiler instructions only give diagrams for their own stats/programmers. Within the boiler there is a room stat link wire (terminals 25 & 26), and also a link in terminals 19 (ch timed on) and 20. I'm assuming it's gonna be one of these but and advice appreciated.... :)
Take the link out of 19 and 20 then connect your in and out to those terminals. You might need to link the live to the in at the wiring centre check the manual for the boiler
Thanks, that's reassuring as I did this yesterday...I will be on Holiday when the plumber turns up to commission the boiler so hopefully it'll all work! I didn't link a live to the 'in' at the UH3 though, the boiler instructions didn't mention this.
Cheers :smiley2:
choice of 3.
1. it works.
2. it don't work.
#3. it goes bang.
what's the problem?
I'd personally say 25 and 26 and keep the link in 19 and 20. Don't link a live just in case its a clean pair of contacts!!
Reason i say 25 and 26 is becuase when the 19 and 20 contact closes (when the heating set to come on if using there programmer), it will then look at the stat terminals... just like any basic heating diagram (series circuit), hope this helps.
Reply to UH3 to boiler connection help please... in the UK Electrical Forum area at ElectriciansForums.net
Anyone tell me where to connect the two wires that switch the boiler on via the programmer and the 2 wires that call for heat on the ufh control...
A question if I may before I dive in. I have an old gravity fed CH system which thanks to members here in the past - works very well. It has a...
Hi. We are looking at installing a Wiser smart heating system inc. trvs We are currently electric only, with normal rads and a Heatrae sadia...
I would like to replace my ancient Honeywell mechanical thermostat with a Honeywell T3R PROGRAMMABLE THERMOSTAT I have three wires in the old...
