Discuss Uk power network complaint iso in the UK Electrical Forum area at ElectriciansForums.net
i have been requested by the company installing new sub mains to each flat in a block to install a uk power network complaint double pole isolator which will be situated between the flat owners meter and fuse board. (Meter tails)
I normally install a Wylex 100a double
Pole ISO.
Is there a common iso used that UK power networks like?
I suppose a call to UKpower networks would be good but I can’t deal with call centres today
Pole ISO.
Why can't they do it? probab ly buck passing cuz they don't know what the UK power network use, watch yourself Mate.
Pole ISO.
most of the ones ive seen in new builds have been wylex
DNO don't have to comply with BS7671, and therefore don't need to consider 421.1.201.
Last time I checked with my Scheme, they suggested the designer of the install in such circumstance would have to carry out a risk assessment on whether a fire was likely to spread into property.
And before anyone says an isolator is not a 'similar switchgear assemblies'. I'm not saying it is, but when I've asked my Scheme a definition of, I get different answers, depending if there's an 'r' in the month. Just something you need to cover your butt about.
PS seen those Proteus installed in a few newbuilds recently.
Reply to Uk power network complaint iso in the UK Electrical Forum area at ElectriciansForums.net
I am doing a new consumer unit install on a second story ex council flat. I’ve notice the mains come in in metal conduit with no CPC. On checking...
I'm planning a replacement for my existing domestic CU and would like to have it sanity checked before I get an electrician involved. The main...
4K
Hi, I have received conflicting advice about Main Isolator Switches and would appreciate forum member's help to plan a way ahead. Looking to the...
Deleted member 155212
Hi everyone. The owner of the business I work for along with myself have created a DIY inverter setup that is giving us some issues. We bought...
