Discuss Understanding led & lowering energy cost in the Lighting Forum area at ElectriciansForums.net
J
jquadri
Would it be fair to say there are two types of recess lights: Halogen and LED, I am trying ti replace the Halogen recess light with an LED recess light.
The electrician tells me there is no transformer attached to the Halogen lights, he said the Halogen fitting constitute 9w and 50w within rooms. I have no idea how this mixup happened. I also think its strange to connect a 9w or 50w Halogen spot light directly without a transformer.
He also said these Halogen recess lights have no transformer. In switching to LED of say 4w, should we also be investing in a transformer? I am told LED lights come in ac and dc. Is it better to purchase an ac based LED, or purchase a 12v 4wat led.
My aim is to save monthly energy in my switching to LED. I realise my initial investment would be great, but I want to ensure I do it right.
Sorry I if seem confused about my knowledge on LED.
convert to 5watt GU 10 LEDs (240V). ditch transformers if there are any and if necessary change the lampholder. if you look at the bulb itself, the 12V ones have thin straight pins. the 240v GU10s have thicker pins with knobs on the ends.( that's the best way to explain the difference without pics.).
From your description you have a mix of halogen light bulbs (50W) and (probably) compact fluorescent light bulbs (9W), however they will all be GU10 fittings as there are no transformers.
Therefore you can change the bulbs to, say, 5W LED GU10 bulbs without problems (unless you have a dimmer switch).
Thanks the
The current recess lights looks like the first picture (pin). I dont think the GU10 will fit bacause of the circle heat. Would I have to change the entire holder with a GU10 holder.
you need to pull a fitting out and see exactly what you have.post a picture.
Thanks the
The current recess lights looks like the first picture (pin). The one with
I think you should consult another spark. Your OP doesn't seem correct to me.....
How many light fittings are you talking about?
There are about 80 lights
Thanks a lot, this is what we have currently
At this point, from your advice I would need to replace all the light holder inorder to fit the recommended GU10. I realise we would need to make a big investment now, but it'll pay off in a few months when the loenergygy LED kicks in. Final question, can you please recommend a good GU10 holder to purchase.
Let me add that this work will be carried out in our holiday home abroad, which is why I want to purchase the parts in here in England before we go back.
Ouch.... you should get a couple of people to visit and give you their thoughts ..... and don't go running out to pound land for cheap carp as you could land yourself in the pan!
If its an office maybe consider replacing them with LED panels.....
Thanks, this requirement is for our holiday home abroad.I dont have the luxury of shipping someone from England just to visit. I want to but everything required to replace the current expensive halogen installation with a GU10 layout
if it's abroad, you need to confirm the supply voltage.
Reply to Understanding led & lowering energy cost in the Lighting Forum area at ElectriciansForums.net
Hi all, Great forum with lots of advice read and greatly received over the years! I have a question here that I am hopeful somebody here can...
Good Morning, I've used this forum for advice many times but this is my first time posting so I hope that this community can help! We're...
This is the second set which won't work to replace the current spots here in my kitchen. All they do is flash once quickly. I'm replacing...
I purchased a house that has a really cool 12v halogen setup where two wires are suspended across the ceiling in two different locations, and each...
In this article, we discuss the running costs of different types of light bulbs in the UK. We compare the costs of CFL and LED bulbs and show how...
