Discuss victron info needed in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
R
rwood1981
My brother in law has purchased a fishery and with it he has a lodge and another wooden building which both have solar on them as there is no electric supply on site. The systems are victron. There are about 8 batteries on ech system. I have no experience in solar but we are wondering if the system will be enough to power the lodge through the summer when its hired by angers? There are 5 rooms with lights 1 tv and the cooker is gas and kettle used on the gas. also a combi boiler.There is a display that reads 24 2.6 I presumed the 2nd figure is what power is being used as when we turn all the lights on it raises up. What is the first figure and will the generator only be needed in the winter? I know it depends also on what is being used but for the lights and boiler will it be ok
I'd guess the first figure may be the battery voltage...
What is the name and model number of the Victron unit? Maybe some photos of the setup would be good if you can attach some.
Reply to victron info needed in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Greetings, everyone, After dedicating over a month to researching Solar PV systems, I'm nearly ready to make a decision. I owe my progress to...
I am trying to understand how a relay system works and have designed a circuit and a ladder diagram all as attached for an 8 PIN relay, a current...
Hello Is it possible for solar panel monitoring to over state the actual power generated by the system? My friend’s 6.4kW system has generated...
