Discuss Wago connectors in a ring main in the UK Electrical Forum area at ElectriciansForums.net
Bul
Some Wago connectors are rated at 24 amps and take cable up to 2.5mm. Would you use them on a ring main circuit?
My concern is that if one leg of the ring went open circuit, the wago would be then used on a radial circuit protected by a 32a mcb.
Bul
Considering that 2.5mm cable is also rated at 24A (before any correction factors), yes.
Your concern is justified, and that is the reason why I never use ring final circuits, I always wire in radials on 20A breakers.
2.5mm cable is rated at 27amps before any correction factors. Nothing wrong with ring finals or 24 amp wagos on a ring, ok if it goes "open circuit" then the circuit has been damaged, the same way a radial circuit might be damaged and loose its cpc.
The point is that if the ring circuit becomes a radial circuit the 24 amp rated wago would be on a 32 amp circuit.
and so would the 2.5mm cable. If your talking about altering a ring into a 2.5mm radial then you would have to change MCB to 20amp and 24amp wagos would be ok
The 2.5mm cable is also rated at 24A. If the ring became a radial, the 24A cable will also only be protected by a 32A breaker. There is no issue with you using the wagos.
Edit: Jonny66 beat me to it :D
Great news! Lets all wire our rings on tray and in free air from now on! I quite like the 'industrial look', I reckon it will go well in the living room! I don't think it will take much persuasion to get my customers thinking the same way :D
I know some steam punk type people who would love that look in their houses, cheaper than MICC... :lol:
I guess if you could guarantee a very low temp permanently as well (but still within the limits of the cables operating range....) you might just squeeze it up to 32.....
Reply to Wago connectors in a ring main in the UK Electrical Forum area at ElectriciansForums.net
Good evening. Currently sorting out my girlfriend’s flat for rent. I’ve found all sorts of bad electrical work. Can anyone advise if this is an...
Hi guys I am looking to add 4 additional sockets for a room that is being converted for a bed ridden person. The room at present has no sockets in...
Hi, I need to swap out a damaged 30A junction box on an existing ring main circuit and thought I'd replace it with Wago 221 connectors and a Wago...
Grateful if someone could offer some advise, I'm struggling to find a definitive answer to this. I have a double socket, it was on the ring main...
Hi all I would like to put some sockets in the attic and keep them on the main house ring main. Am I right in saying I can pull one of the legs...
