M
MDJ
Anyone ever tried to twist a wago when it's on a cable? I did a joint earlier in the week with a 32 amp wago which can take .75mm2 to a 4mm2 cable, according to the instructions it can be used by both stranded and solid cores, I pushed a wago onto a 2.5mm2 solid core, The spark I was working with tried to pull it off the cable to see how strong they were, he failed, I tried and failed, the connection held, however the actual wago could be twisted on the cable, anyone else had this? we assumed they have been tested to BS and must have passed the tests, if so how can a wago which can twist on a core be adequate? seems strange to me, I may write to the company about it.
