Hi all, new to this forum so forgive me if I break any rules/etiquette.
I had a family member install a circuit for some wall lights a couple of months ago. The lights just need connecting up and I don't want to bother him again to do that as he works away so doesn't get much time off.
Okay so one wall light is straight forward- one twin and earth cable, so I'm fine connecting that up.
The other lamp has two T&E cables- one for the feed and one from the switch? He's also run a new cable to the switch that's not yet connected. So my question is, on the lamp fitting with two cables, can I just connect all the neutrals to neutral on the lamp and all the lives to live on the lamp, or is one of them a switched live?
Am I also right in thinking that at the switch end, live (brown) goes to common, and neutral (blue) goes to L1 / L2 with some brown/red tape or sleeving to indicate switched live?
Any help very much appreciated.
Thank you, Beeg.
Thank you, Beeg.
