N
NeoCool
Hi I have a question that im pondering on for a few days now.
I have run 6mm SWA 3 core from my house to my new workshop. Single Phase
It comes from underground 600mm laid in sand 150mm then soft ground then hard.
It comes from under my workshop and up into the workshop floor up from the corner.
I have my garage consumer unit and my questins are about the regulation requirement.
Im guessing i cant install my consumer unit right in the corner with the SWA coming up from underneath it.
So thinking of putting my consumer unit 300mm in from the corner, but to avoid a big bend in the SWA before it goes to the consumer unit, im thinking about keeping it straight up and terminating into a box.
Before it then goes by a bit of conduit accross into the consumer unit enterning if from the right.
Quesitons can I use a plastic box, or do i need to use a metal box to terminate the SWA Gland?
what do i do with the 3rd earth core if im using the swa as the termination in the box?
And what do you think of my above senario is it under regulation or not.
Any feed back greatfully recieved.
