Discuss what Can a restricted licence holder do? And can’t do (south aus) in the Australia area at ElectriciansForums.net
service and repair of anything that plugs into the mains,
fixing plugs and cords for instance
But no permanent instalation work
I,E. you cannot fit/wire switchs or gpo's
unless someone licenced signs off on it !
To fix anything that plugs in, you need a licence period.
Thats the law !
Reply to what Can a restricted licence holder do? And can’t do (south aus) in the Australia area at ElectriciansForums.net
If one of your coworkers suffers a severe electric shock, your first instinct will most likely be to rush to their rescue. But first, pause and...
Not sure whether this is the right context or even forum to mention this, but I’ve recently been offering out myself to a friend to help get his...
Long shot but thought I’d try, have a lighting circuit that trips the RCD as soon as the neutral touches the neutral bar for said RCD. Bypass that...
The lamp holders on the 2 lamps I have made are very wobbly. Would you recommend a glue? What type of glue? Thanks ☺️
