Discuss What is this box and cable on the side of my house? in the UK Electrical Forum area at ElectriciansForums.net
QUOTE -
I was told by my supplier that it is bypassing the meter
Is the power going out and am I paying for it?
but what is its function?
if it is bypassing the meter ?
then you ain't paying for it !
BUT
some form of common power seems most likely
like walkway lighting.
but we are just guessing.
Like someone has said above, if your meter and fused are outside, accednetly make the fuse fall out and leave it in the enclosure, if no one complains after a few months accednetly get it ripped out and deny all knowledge. For legal reasons my name is Mr Smith and I live at number 2 Lybia Road, Lybia.
If you own the house, details of such a box should be on the deeds
House Deeds are now digitised and held by Land Registry.
It only records property register, proprietorship, and if there are any charges. There is also available a map displaying the boundaries of the property. Nothing else is held or stored. Any other documents that might have existed, may be with the solicitors who carried out the conveyancing or the mortgage provider, when you purchased the property.
I make this point, as when I tried to recover documents, that I knew existed from my solicitors, they could not be found. It didn't help the fact, that my solicitor had past away.
So, if you know of some important documents or of a personal interest, get onto your solicitor or mortgage provider, before they get shredded.
It varies. There are also often details of rights of way, neighbours rights/access for maintenance of their and sometimes covenants that are in place (mine state that I can't run a business from it, and that I can't have a fence or hedge above 2 feet high :) )
Just curious, have you actually found out what documents the Land Registry have of yours? You might find, they don't actually anything other than I previously mentioned.
I had documents relating to access and ownership of fences for example. None of these were stored with the Land Registry. They are either collecting dust in some solicitors/mortgage lenders storage, or were shredded in 2008 when LR went digital.
Where are my title deeds, what are they and do I need them? - Land Registry - http://blog.landregistry.gov.uk/title-deeds/
My deeds (physically in my ownership) include that stuff, but I see now you are referring to deeds held specifically by the land registry. Must admit I don't know what the land registry hold for mine.
Reply to What is this box and cable on the side of my house? in the UK Electrical Forum area at ElectriciansForums.net
Hi, i live in a new build house where they builders have left a junction box on the outside of my house. In the junction box there is a 6mm twin...
For various reasons out of my control, we have wound up in a situation where we have 1.5mm SWA cables buried in these pillars and exiting out of...
7K
Good morning all, I am currently working on a House in Multiple Occupation (HMO) consisting of 10 flats, with three parking spots equipped with...
Hi I've got an new outbuilding that needs power run out to it, the building is very close to the house and the original plan was to run an...
