Discuss What tests for new radial circuit in the UK Electrical Forum area at ElectriciansForums.net
Job is to install one or two new sockets in a commercial premises.
Possibly on a new radial circuit or an extension to ring.
If extension on a ring them a Minor electrical certificate is required together with all relevant testing.
However if a new radial circuit is the way a full EIC certificate would be needed. What would be the extent of tests required, not sure if there is any previous inspection and test certificates available.? In short the testing could take much longer than the small job itself.
if you add a new circuit, you only need to record test results for that circuit, along with Ze, supply characteristics etc.. everything else, you put "existing" on your schedule of results with no readings. obviously, ensure that the installation as a whole is fir for continued use.
Reply to What tests for new radial circuit in the UK Electrical Forum area at ElectriciansForums.net
We have a room in the house that was the kitchen. That has been relocated to a different area, so the old kitchen has been sold off and the room...
Hi I have a job where customer has two families one families lives upstairs and one family will live downstairs. As the property is going through...
Hello, Last year I had some electrical work completed in my house (New CU, SWA for garage, downlights) I informed the electrician that I will be...
Hello, I am in the process of training to be an electrician and have a question. When filling out a EIC for a new circuit am I required to test...
Hi. A few years ago we had a full house rewiring done by an electrician who issued a certificate for the work. He also left in the consumer unit...
