Discuss What’s this? Is it a? in the UK Electrical Forum area at ElectriciansForums.net
The property its at...any communal lighting. I work in social housing and round various blocks of flats etc someones meter cupboard has one of these in and its a CU for rhe communal lightning. Slowly replacing them though
And the winner is 60A Switch fuse.
Am I right in thinking that the out going tails at the top are some sort of mineral insulated cable? They look about 16mm and are on roughly a 7m run to the main DB in the house which has a 100A main switch.
I recall installing those things (not that particular one) when I started circa 1970’s. You know, when there was Austin Maxis and Hillman Imps.
They could be, but the round copper sheath cable will be the clincher.
funny, just rewired one similar. the wylex version. builder got no power as was dissed, so fed a couple of tails to the 60A switch fuse then a double socket for temp. power so he can brew up and use his 110V toys. OK it's over fused but plugs have 13A fuses.
Yes that's mineral insulated cable, imperial size by the looks of it.
If you need to alter/reterminate it and are unsure of how to go about it I'm in the area and happy to lend a hand.
Cheers Dave. Must admit I’d like to have a play with some MIC at some point. May well post some more picks on this job. It’s an old 2 up 2 down 16 century cottage, not listed, and the wiring is a real mish mash.
That is approximately 14.52mm²
Fixed that for you. But it's exactly 0.0225 sq. ins. FWIW that was a popular size for PILC service cables.
So yes, imperial MICC. In this case, the sleeves have the imperial cable size on, but even without that, the fact that they are headed sleeves that disappear through a tufnol disc, and that the compound is green, point to the imperial era.
I agree that the earth connection using a female bush is not well done, it should have either a coupling and bush, or at least a lockring. And, of course not be completely inaccessible!
Nope. Private semi detached cottage. Overhead supply to this intake which is on side of garage.
Reply to What’s this? Is it a? in the UK Electrical Forum area at ElectriciansForums.net
Hi we have been asked to run a 3 phase supply into a boiler house to feed a DB fed from next to the existing meter. Would we need to install Tails...
Hi guys, could someone help with the following please? The scenario is: Domestic property supplied via three phase (with a 3P main DB, NO SPD)...
I wondered if it is OK to have 2 x Main Switches in the same consumer unit. One feeding the RCBOs in the House and one feeding the CU in a garage...
Hi everyone, A diversity question concerning 2 consumer units fed from 100amp DNO supply Background, So I have an 18th Ed compliant consumer...
Hi, I have received conflicting advice about Main Isolator Switches and would appreciate forum member's help to plan a way ahead. Looking to the...
Deleted member 155212
