Search the forum,
Discuss Why would a 20 amp outlet only work if the 30 amp breaker is on? in the UK Electrical Forum area at ElectriciansForums.net
I have a champion 7500 electric start Genny, model no 100463 that I bought second hand. I was told it was gently used but have since noticed that it has been tinkered with. My question of the day is;
When I plug into the 20 amp outlets, I have to turn the 30 amp breaker on to be able to use the 20 amp outlets. I was told this is irregular. Is it and if so, how do I rectify this issue
The circuit indicates that, for each circuit, the 30A breaker is in series with the 20A breaker. Therefore it seems they both have to be on, and that's a design feature. As above, don't believe what you were told! 🤪
As per the schematic, the 30A breaker is an overall one that protects the alternator from overload from all outlets combined. Then the 20A breaker protects the 20A outlets and anything plugged in to them. If the breakers were independent then you could draw a total of 50A and overload the alternator.
You really can’t modify your generator because it will probably cause more problems than you already have. You are taking a big chance when you buy used equipment. If it was me I would just leave it the way it is and just turn off the 30 amp switch or unplug your generator.
Reply to Why would a 20 amp outlet only work if the 30 amp breaker is on? in the UK Electrical Forum area at ElectriciansForums.net
Mobile home outdoor power supply is a pedestal that power to the mobile home plugs in much like an RV. The main power supply into the mobile home...
New member and DIY. I have a 60 AMP breaker going to a sub panel for a workshop. Two months ago I bought an electric car and a 40 AMP charger...
Apologies up front but I'm a DIYer and only got 1 reply on that forum so trying here. I'm in Ontario Canada where a homeowner can do there own...
I would like to ask advice on a breaker size. Back in 2001 I turned my garage into a woodworking shop with several 240v machines. To power them I...
Hi I have a 1 bedroom appartment from 1954. I opened my breaker box to find out what the extra double 20 amp was used for and I realized that it's...
