Discuss Wire and hot pipes in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
T
tedglen2
Hello – looking for some advice. I had an electrician rewire the house. He has finished over two weeks ago. I have pulled up some floorboards ready for some bathroom plumbing and have noticed. Some of the wires cross over the central heating pipes. They are about 1cm off from touching!!! Is there anything I can put over the pipe to stop the wires resting on the warm pipes?
Without rerouting pipes or cables, the easiest thing would be to put foam lagging on the pipes.
edit...
unless they're going through holes or in notches!!!
Ted, weren't you doing the wiring under the sparkies supervision? That's my understanding from the previous threads mate and if so he can't have done a very good job of overseeing that bit of the install and you don't really have much of a comeback I'm afraid
Get him back to re-route the cables correctly. Tell him to look at the big green book, 522.2.1.
Is the BGB printed in Polish... :lol:
dont see what esle he could have done. the wires would have to cross pipework at some point ? they not touching the pipes, i am just worried that if the wires go slack over time then they will be. The foam insolation should be ok ?
Do the cables go through notches? Are the notches covered with anything? Do the cables cross above or below the pipes?
cables go through holes... most cables run below but there are a few that run over in certain areas where the pipes run low. will the foam pipe stuff be ok on the warm pipes ?
I take it the pipes are parallel to the joists and the cables are crossing over the pipes...
I'd be happy with the foam insulation, it does work very well.
so do as said. insulation overr the pipes where they are close, as per archy's excellent picture ( bet that wasn't done by a wet-head.)
true, but insulation works both ways. it stops cold getting in and also stops heat getting out. the alternative is to lag them with asbestos, but not recommended if you want to live as long a me.
Get the sparky to rewire your house again. Im sure he'll be happy to oblige. It is, after all, easier than slipping a little bit of insulation between the pipe and cable.
Why was it not done properly in the first place?
Reply to Wire and hot pipes in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Electrician has done rewire, plumber with not much space has some central heating and hot water pipes touching in some places. See images...
I'm in Raleigh, North Carolina and have a well for my house's water supply. For some reason, pitless adapters, which allow all piping to be run...
I removed my baseboard electrical heaters (1981 installed) due to finishing off the room. When I had a new AC ductwork installed they changed the...
Hi All, I own a country Villa out in the Spain countryside. Was having problems with water pressure so local tradesmen advised to get a water...
Well....wiring in a 1750s thatched cottage attic, not wiring made from thatch 🤪 One we have been letting for over 20 years (as well as enjoying...
4K
