Discuss Wiring 120Vac and 480Vac 3 phase in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
A
Abe5gt
I am wiring a actuator that has 480V power and 120v control wiring. I was wondering if I could wire them through the same conduit.
Both voltages are recognised as LV so unless there are other reservations you have then they're both fine in the same containment.
As the OP has not stated his country of residence and the nature of the voltages expressed i don't think we should be giving him the green light based on British Standards7671 until we get further info'
According to NFPA 70, the insulation of the control wiring must be to the same insulation value and of the same temperature rating as the 480V circuit, when enclosed in the same containment system.
Hi boydy where does it state this. I often find 110v / 230v / 400v in the same containment in industrial applications
Yes you will but note the dielectric strength of each conductors insulation will be rated to 500v probably so acceptable, 414-4-2 (iii) also allows pelv/selv to mix with LV as long as the insulation is rated to the highest voltage present.
Yes but a conduit would normally come from a trunking and go to a single piece of equipment/socket or whatever.
A trunking would carry multiple circuits normally.
The op said conduit.
Boydy
Definition of conduit in English:
conduit
con|duit Pronunciation:
noun
  • 1A channel for conveying water or other fluid: nearby springs supplied the conduit which ran into the brewery More example sentences
    • In this case, the floor drain provided a conduit to the storm water sewer and a nearby creek or drain.
    • Roads, railways, water supply conduits, power and communication lines, towns and cities were built to a high technical standard.
    • They consist of a single piece of hardened steel, and their hydraulic fluid conduits are contained in the jacks' interiors, allowing for safer, more efficient operation.
    • Get more examples
  • 1.1A person or organization that acts as a channel for the transmission of something: as an actor you have to be a conduit for other people’s words More example sentences
    • Microsoft issued a workaround today to guard against a serious vulnerability in Internet Explorer which created a way for hackers to turn popular websites into conduits for viral transmission.
    • The spectacular advance of AIDS resulted from a virus given new routes of entry: widespread increases in certain lifestyle practices provided a conduit for efficient transmission.
    • They do not enlighten but are used as conduits for making money by religious organizations.
    • Get more examples
  • 2A tube or trough for protecting electric wiring: the gas pipe should not be close to any electrical conduit [mass noun]: the cable must be protected by conduit
    Origin
    Middle English: from Old French, from medieval Latin conductus, from Latin conducere 'bring together' (see conduct).
Reply to Wiring 120Vac and 480Vac 3 phase in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
BIG place OK lots of electrical bits. but one on a 3 phase Radial is tripping its RCCB so i check the wiring making sure its tight and it has...
Hi Guys, We have a CNC router which uses single phase for the spindle, stepper motors and control box. This is all wired in and working...
Absolutely losing my brain here guys What I would like to be able to do is power our 3 phase motor on a single phase supply. Thought I had it...
Hi all, I have two questions regarding wiring and containment on commercial property stairwells in Ireland. We are currently wiring a 3 story...
