Discuss Wylex dis boards in the Australia area at ElectriciansForums.net
I have come across this situation a few times and need some advice . The old wylex boards with re-wirable fuses can be changed to Mcb's really easily , would it be better to change the entire board .is changing the fuses to breakers considered to be renewing the board ?any one got advice?
It does depend which wylex boards you are talking about , 3036 rewireable fused boards still comply with the regs , how ever work requiring RCD protection will require an aditional board ,as RCD's dont fit the old boards and you cannot install an RCD to cover the whole board , also some of the wylex boards the early ones have a wooden frame at the back which can be a fire hazard if the board developes a fault within the board , this is quite common , another no no is with the wylex boards if you install minature MCB's in the board and the fuse cover is not adjusted to fit then you are exposing live parts so care should be taken , i always recommend that a customer upgrades to a new board mainly for added protection and easy of resetting tripped mcb's compaired to rewiring a fuse
for a 6 way board the MCBs to replace the 3036 fuses cost about £65 - £70. for virtually the same money you can get a dual RCD board, fully loaded. pointless excercise fitting breakers in old board. bit like fitting the titanic with disc brakes
Reply to Wylex dis boards in the Australia area at ElectriciansForums.net
So here is the thing Rhere is an old MEMSHIELD TPN+E Board that is pretty mich obsolete. The only place that sells their breakers would be Ebay...
I may well need to change all the MCB's for RCBO's in this board (see picture). Do Wylex RCBO's fit in this board? It is currently fitted with...
8K
I had Scottish Power moving a supply this morning from one building to another so an extension could be built. I had everything ready for them...
I try to keep out of Domestic work but I have a problem at home. Currently I have a wylex fuse board with re-wire fuses. they are great because...
4K
Hi all, I am looking for some advice regarding old rewireable (3036) fuse boards in regards to additions and alterations. I am an electrician and...
4K
