- Feb 23, 2020
- 117
- 159
- 118
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- Practising Electrician (Qualified - Domestic or Commercial etc)
Setup:
Consumer unit fed via sub main from a 60A fused isolator switch. This is connected to the service head MET via a 2m earth connection.
How would one go about both calculating and documenting the Zs?
Would you be treating the fused isolator switch as it’s own db and therefore be documenting Zdb1 (at point of isolator switch) and Zdb2 (at consumer unit). Zdb2 would be be the reading minus Zdb1? Or would you do Zdb1 and then the R1 + R2 of the sub main?
I’m getting myself confused so if anyone would be kind enough to talk through how you’d test this setup it would be hugely appreciated?
