Stuff it............back to the wylex rewireables with bakelite backs for me. I've certainly seen more burning damage to cb enclosures.
I've posted this before ...
I've no idea how much sway that BEAMA have in all this, but I'll just bring it your attention again...
Clearing the fog around the new Consumer Unit Regulation - BEAMA | News
Quote from below the picture of the geezer,
“A further point for clarification is that plastic enclosures manufactured from 960 degree glow-wire rated material would not be classified as ‘non-combustible’ in the context of this regulation.
Have read it, very useful. (Not) Chocolate tea pot comes to mind.
love there definition of non combustible material ie There is no published definition of combustible material that aligns with intent of regulation 421'1'201. ?????
Yep chocolate tea pot !!!!!!!
I'm of the opinion that I'm not against this Amendment. I appreciate that plastic is easier to fit than metal and is cheaper. I also take on board what the OP is saying about product standards and more to the point installer standards. If I knew nothing, I would hope that the person who said to me that my consumer unit needed up dating, as is usually the case, not often do you have the home owner phone you up and say, hey I think my consumer unit needs changing, would be installing products that are safe. As the guy from Beama says "this new regulation is intended to provide a level of enhanced fire risk protection". Metal is stronger than plastic. Metal would be deemed by most people on the street as being a non-combustible material. If you stopped and asked people in the street which material they would prefer on safety grounds, without them knowing all the facts, then I would be fairly sure most people would choose metal.
I wonder if the manufacturers prefer to sell metal CUs as it may be more profitable. They don't seem to be fighting the wording/semantics/interpretation of the reg at all.
Of course they do, don't we all want to be more profitable and they aren't going to be semantic about it.
I find that consumer unit changes in domestic households do not hold the same amount of weight as a boiler change, for example. The plumber gives you a new shiny Worcester Bosch 24cdi for 3k, brilliant I hear you say, along comes the noble sparky and says you need a new consumer unit. The safest and best solution is to have an 8 way rcbo consumer unit which complies with amendment 3, most larger manufacturers are making them in metal (Hager, Wylex, Schneider so far...) it will cost you £500, HOW MUCH! know way am I paying that for something that I don't really understand and doesn't make me warm or make my hot water nice and toasty, forget it. I would like to see domestic house holders being more educated on the products that are available to them and what they should have to be safe, but as with most electronic items in this world, all want the cheapest. This is not the correct attitude with regards to electrical safety. Fitting metal consumer units in domestic premises, screams safety, perhaps over the top but that’s what it’s all about today. I would also advocate the necessity for legalisation of electrical work which falls under part p, as written in this months Professional Electrician to help protect against the people who don’t give a sh*t.
everyone takes electricity for granted. No one cares until someone is injured or killed. All people think is...if it works..great
No it doesn't, ....it screams ''knee jerk reaction'' based on flawed data provided by LFB
I've seen cases of metal DB fires that if were located in typical domestic settings could have taken the the house with it. Now these were American DB's but they were metal construction and the wiring to these DB's were similar to that used in the UK, eg solid conductor T&E. The wiring was virtually completely destroyed for around half a metre beyond the metal DB enclosure.
If metal CU/DB's screams safety, why do you never see a metal consumer unit or DB in any German, French, Dutch, Belgium, etc, etc, etc domestic installation?? Why do they not have the same amount of consumer unit/DB fires, it maybe because there electricians are required to have a damn sight more training than 17 days/5 Weeks?? In fact you'll be lucky to come across a metal DB even in commercial and small industrial situations within Europe, ....Are they somehow using different plastic's to those used in the UK. Strange because the same manufacturers that supply the UK, supply our friends in Europe as well.
The same overall cause of the present problem(s) in the UK, will be transferred to the metal CU's, in fact it could well introduce more problems.....
Reactions: 3 people
I still don't understand this farce, I've never seen anything quite like it. I've always held the UK standards in high regard until recently a couple of things have made me wonder. One was the knee-jerk earthing requirements for electric vehicle chargers which I understand they back peddled on for the mostpart and now this.... It's the fact they're attempting to electrically regulate an issue that is clearly not a electrical issue which means they're treating the symptoms and not the root cause which I suspect is a combination of falling materials quality standards and falling installer standards. Add to this the fact that there's a lack of clarity. I can understand the wholesalers ignorance, I wouldn't expect them to worry about anything other than their bottom line but even industry associations and groups can't agree on the implications and the precise standards of consumer units that should be installed.
Reactions: 5 people
Couldn't agree more. I wonder if this farce will be changed/altered at the next Regs amendment.
Until you lot start writing the regs. change the record, it's metal CU's in the UK, until some other idiot who writes the regs says otherwise. I think the rule about drinking & driving is ridiculous and should be changed, it impacts on my human rights.....:angel_smile:
Only in domestic set ups from 1st Jan 2016
Nice plastic ones in commercial/industrial - go figure
However, a plastic CU is going to be perfectly acceptable in a commercial setting thus implying that the CU and the terminations it encloses are less dangerous than those employed in a domestic setting. Just like the introduction of Part P implied that electricity used domestically is more dangerous than a commercial or industrial setting.
Bolox. It's a sticking plaster over a gaping wound
No record to be changed. Plastic to BS EN 61439-3 will still comply.
I have been in contact with the Niceic( who we all know change there mind every ten minutes) in February they did confirm than as of then steel was the only non combustible material that would conform with the regs, I work for a large housing association and we have already fit over a dozen of Wyler and Crabtree star breaker,, they did confirm however it would be necessary in escape routes and under stairs, we as a company have an Niceic representative and an electruim rep coming to our next tool box talk so I will keep you guys inform. Personally I do agree with everything D Skelton but I don't know the last time people from the Niceic or the IET actually listen to the tradesmen the regs affect
So by implication, if I were to build a domestic CU out of copper it wouldn't comply. Hmmmmm wtf are we going to do now about all those copper bus bars that are out the in domestics?
In the meantime ... :smilielol5::smilielol5::smilielol5:
Me too, it should be no alcohol at all in the system, the current levels are far too high.
You must be tired, after all that post contained so much BS it must have been exhausting to write it :biggrin:
Ooohhh, someone is tired aren't they!
D Skelton
Mentor
Milton Keynes
Heavily Qualified Electrician / Teacher / Tutor - etc
AMD 3 - Hopefully busting the myth of metal DBs
D Skelton,
Midwest,
