Discuss Very old cut out info in the UK Electrical Forum area at ElectriciansForums.net
i haveI'm not sure but I would have the DNO out to look at it.
i have
all he ask was "is anything wrong with it"
and than "we can change it for a fee if you want"
Good point, i am not sure and dno guy put seal on the door nowNope I have seen some old stuff but not that. Is the neutral bar isolated from the enclosure.
This is in 1st floor and supply 2 flats on the 2nd floor.Is that the main incoming supply or in a flat?
There is another one on the ground floor but bigger with 4 fuses supplying ground and first floor.
So re supply to 2 flats, lets "assume" they are rewireable 3036 fuses, probably max 30A - so they are too small for the job (probably).
I think that this "fuse" is down to the flat owner - the bigger one downstairs is probably down to the supplier - where is the meter?
i Ze gave me open circuit but they said that this is not they problem. So i went
Meter inside the flat...
Just had a flick through that, that's a great guide. Are those codes a DNO standard or would they not know what I'm talking about if I mentioned one on the phoneCheck this guide on such issues.
Check the MOCOPA guide I posted. @Jamchiv01 never mind the codes its the condition referred to when you speak to them, that is the point, if they think its bad just describe the item, they will catch on.official info
Please expand on this.......
Silly question But:
That earth connection to the mains incoming, is that clamp just put over the paint, or has it been cleared for a good connection?
From the photo it looks like its just on top of paint.
Brave person to put a clamp on that or any supply cable.
Defo true dont touch the supply cable especially of that age.Is that true
@kropaske they must change it by 2010 it says it in that guide I think. And for free. I am just amazed the DNO attended and left it like that, seriously negligent I would be having a head fit with them. In the nicest possible way!
Looks like it is, the neutral bar seems to be bolted through ebonite insulating bushes to those metal brackets.Is the neutral bar isolated from the enclosure.
The BS951 clamp on the incomer appears to have been fitted to the brass sweating thimble above the wiped joint.
Which DNO is this?
Think you are correct it doesn't "appear" to do anything.I can't make it out is there a hole in the butterfly nuts or is the gripple wire just wrapped around them in other words looking good,But doing nothing?
Reply to Very old cut out info in the UK Electrical Forum area at ElectriciansForums.net
