Discuss Heating timer Replacement in the The Welcome Forum area at ElectriciansForums.net
Hi all, I have just registered with this site as I have a faulty switch in my Danfoss Randall 911 timer and, looking at the www, it appears this has been replaced by a TS715SI. I have purchased one on line and was wondering how easy it is to swap over and if the 'service interval' can be overridden ? Thanking you in advance.
If I recall correctly, the easiest way to avoid having to over ride the Service Interval Timer is to not set it when installing the programmer as it isn't set by default.
Replacing it should be easy enough but safe isolation is not always that straight forward on some heating systems.
Been doing one today which was fed from two different sources which keeps you on your toes I can tell you.
If your not 100% confident with safe isolation and competent enough to know one way or the other I'd give it a dodge and get someone in to do it for you.
Reply to Heating timer Replacement in the The Welcome Forum area at ElectriciansForums.net
Hi I replaced a Flash immersion timer with an apt one today and it seemed straightforward but just wondering should the light on isolation switch...
I’m replacing an old 100mm extractor fan in the kitchen with a new one. The old one was a pull cord fan whereas I bought a timer one (no pull...
Hi Guys Changing my heating/water programmer and im stuck on the wiring ive gone from a danfoss to a Drayton and the wiring description is...
Hi just wondering if someone can help me. I have an rcbo that keeps tripping but only when the fly earth and neutral lead on the bars it trips...
Hi. I am trying to replace a heating timer with a smart switch. The current timer is the type with a dial on the front and 1 to 24 written on it...
