Discuss Flourescent in the Commercial Electrical Advice area at ElectriciansForums.net
I have been asked to change alot of old twin 6ft flourescent fittings in some units, twin 70watts. The new ones will be led, just wondering what the equivalent would be to give off the same brightness. I've seen some 6ft led twins that say 70watts but won't that be to bright as they will be led.
You can buy LED tubes to go straight into the 6ft (70w) fittings.
Brightness is determined by the lumens. Not the wattage.
A decent wholesaler will supply you with an equivalent tube or fitting.
As said better to look at the lumens. Wattage will likely end up being less.
Hi Simon, unfortunately there is a bewildering amount of information to absorb to find that out. If you look into the tech. literature you will find that twin fluorescent give out circa 7000 lumens the only equivalent I have come across is KSR twin LED battens. They are really bright (7000 lumens). The way lumens are measured seems to bear no relation to the real life radiance received on the critical areas as the way lumens are measured by different manufacturers vary. Stated lumens may have no bearing on the lumens delivered to the desk say. Having said that, the human eye is very adaptable and incapable of assaying how much light there is except at very high levels. So if you put in the KSR ones the amount of fittings you will need will be less. As the fittings they put fluors. in block 60% of the light from the tube whereas LED radiate all around so to speak so perceived levels of lighting will be experienced as far brighter. So if you have 8 fluors to replace you may only need four LED. Also there are requirements for lumens delivered at desk height and need to be measured to comply. In short it is best to ask the manufacturer and tell them for what purpose and get in writing from them what is needed to comply with these requirements, sorry to take so long to say that.
Watch out .............. if you have a lot of florries on 1 circuit and change them to LED's, then you could have inrush tripping issues ...................
Lumens are the most important consideration
I'm with Vortigern, the KSR Navara X fittings are incredibly bright. Their 65W fitting more than surpasses the light output of a 2 x 70W fluorescent.
Just thinking times gone by, had a boss owned the contracting business, one guy dropped a 8ft pop pack, he laughed , I cracked a 30p back switch patteress , he went nuts. memories.!!
Is there a rule of thumb in terms of max wattage on 1.5mm cable
Or how do you work out the inrush current? What if the inrush current surpasses the max current rating of the fixed wiring? Is this ok because it's only starting current?
The output for a 70w tube is variable between 6000 and 6500 lumen.
"Watts" and "Wattage" have got to be amongst the most misunderstood terms as far as joe public goes. How many people out there believe that sound is also measured in watts... this misconception no doubt aided by the marketing departments of car audio systems...
I didn't realise you are a spark ........ I thought you were a DIYer
Best you research inrush currents ............... this is VERY different to calculating the load on the circuit.
Reply to Flourescent in the Commercial Electrical Advice area at ElectriciansForums.net
As the title says. But then I cut off a jst connection off one of the light strips and I can't get them to work together... the one strip is plug...
Have been asked to do remedials on an EICR that was carried out a year or so ago by another electrician. Curious to know what code you would give...
This in a kitchen/dining area of maybe a little over 200 sq. ft. (10 x 21ish). Presently have 4 flourescent troffers with standard 2 40w lamps...
Hi we are replacing light fittings in our home. Im confident with the fitting aspect, but have run into doubt in making the right choice of...
I have a street light circuit on land I rent out. I need to replace 2 of the bulbs. 1 of them is an old Philips 55W SOX Plus, the other is a...
