Discuss Do other trades actually think ???????????? in the UK Electrical Forum area at ElectriciansForums.net
O
Octopus
Came across this today, whilst fault finding. Fortunately I didn't need to look inside it or isolate any of the circuits ............
Could get interesting ....
Daft place to put a CU in the first place, Kevlar, hard hat and whatever else I might need well and truly in place.
I thought that was 2 galv conduits and thought why would a spark do that?
Now I see it’s the garage door runners. Can’t really put them anywhere else. Why was the CU put in such a silly place:confused:
True, but anyone with an ounce of common sense would arrange for the electrics to be relocated prior to the garage door being installed.
Client just as much at fault.
I've had this exact same problem- the fairly elderly customer rang asking me to move the CU lower down but the only way I can get to it is for the garage door cretins to temporary remove the door automation assembly and refit after the CU resite, the door itself could be left to manually open and close for security as it would be more than a days work for me. But the board is still in the silly place as they quoted her £800 + VAT !!
I recently did a high end refurb and kitchen which included new CU's in the intake cupboard at one end. Nearing completion I arrived one morning to find Kev had fixed a handmade unit and shelf around one of the CU's so that it was impossible to open the top hinged door flap to access the RCBO's.
"I thought you'd finished?" he helpfully suggested when I enquired what the £&ck he was playing at.
I didn't have to tell him he was a muppet....client was on a site visit and told Kev himself.
mind you, nobody is perfect
This is the 3rd CU inside the main house ..
Its all nice and neat ..........well sort of, but turning off the main switch doesn't isolate all the cables inside it ........ the installer has used this CU to terminate SWA from other circuits in the 2 other CU's to it.....................
Its now sporting a big label warning the next person who opens it
Came across this today, whilst fault finding. Fortunately I didn't need to look inside it or isolate any of the circuits ............View attachment 44913
What a crazy electrician, installing a CU behind those pipes!
PS.. I think all trades are the same, it just depends on the person you get. Some electricians will not think about how their work affects other trades and some will, just the same with plumbers, plasterers etc etc.
Of course we're the best though, so that does kind of give us a right to do what we want.
option 1: move CU.
option 2: installl roller shutter door.
option 3 :customer is a numpty and deserves what he gets.
Normally mistakes happen, and things get obstructed by one trade or another, it's inevitable on some jobs, but being Human and caring we get over these things one way or another, you could blame the Electrician for putting the CU there, equally the Plumber is a complete Idiot for installing those pipes, looks like the art of consideration and communication are a dying art, terrible to carry on, the Plumber probably though well I need the money not my problem if the CU can't be opened, I have had this sort of thing happen on some of the jobs I used to work on, makes you want to take the culprit to one side and give hi a stiff talking too.
3rd-cu-jpg.44920
Hang on... That PSU is din mount, supposed to be in an enclosure. The primary power terminals are fully exposed :confused:
3rd-cu-jpg.44920
One installation had a split board with the main switch and breakers inside the cupboard neatly separated from the RCD and associated breakers by the cupboard side. No cover for the CCU.
The same installation had a long flexible cable from the CCU to a tree in the garden connecting to a metal garage unit supplying the garden lighting!
Reply to Do other trades actually think ???????????? in the UK Electrical Forum area at ElectriciansForums.net
Hi Folks , Just looking for a bit of advice as I'm looking to get back on the tools so please bare with me if this is a bit long winded. I'm a...
Hi there, I’m a new member to the forum and felt like I could do with some additional insight into a fault I came across on a call-out at the...
I'm in a questions asking mood tonight. I briefely looked at a job today and I need to recommend a board change but need to justify it. Firstly...
Hello, Is there an actual age limit on house wiring that would prevent a traditional fuse box being replaced with a consumer unit please...
I'm writing this mainly hoping something occurs to me while writing it! I got called to an occasionally tripping RCD. It's a Hager double height...
