Discuss fitting a pir near roadside in the UK Electrical Forum area at ElectriciansForums.net
got a job fitting a pir near side of road (4 metres away) to contol 2 led floods any tips to avoid cars or pushbikes setting it off ,i can point it down and buy one with sensitivity control but any other tips please
PIR motion detectors detect the movement of heat...….hence they are motion detectors. In other words, detecting both. Stand perfectly still and no operation.PIRs detect heat not motion. At least that's the case with alarm systems that I've worked on. You should be able to adjust the range to its minimum and point them down. Just need to work it out.
What's all that got to do with it?Yes. That's true. If the heat source happens to be moving. But the fact that the heat source might be moving is irrelevant. If the moving object is at ambient temperature then a basic PIR won't detect it. They are heat sensors. For example, if someone throws a rock through a window a standard PIR won't detect it. That's why Honeywell, for example, provide Dual Tec sensors. They use both passive infra red, to detect heat sources, and microwave technology to detect moving objects that don't have a heat fingerprint.
I know it's off topic but just clarifying my first comment which you challenged. Here is a picture of a brick. It was thrown through a window. The PIR is just above my head when I took this picture. It did not trigger and it was functional. I tested it afterwards. I replaced all PIRs with Dual Tec.What's all that got to do with it?
A PIR motion sensor takes a moving heat source to operate.
It would've triggered if they'd jumped through the window after smashing it, though.....
No doubt, it was.Perhaps it was just criminal damage.
The photo was "staged". I put the brick there and took a picture of it for insurance purposes. Staff had moved it and started to clean up by the time I got there. But here's the glass and here's the window.That photo looks staged.
You're welcome.Thanks. I'm happy now
Poor Midwest and his ‘euphamism’ used to describe his ‘manhood’ ;-))My neighbours PIR detects my leafless tree, swaying in the wind
And my neighbours detects the wind and nothing elseMy neighbours PIR detects my leafless tree, swaying in the wind
what's the point of keeping a leafless tree? that's like having an alcohol free beer.My neighbours PIR detects my leafless tree, swaying in the wind
but the beer in my glass won't grow back. i have to go to the offy. maybe i should plant a beer tree in a barrel.You silly sausage, the leaves grow back in the Spring. Watch a bit more Gardeners World, you'll get there.
Reply to fitting a pir near roadside in the UK Electrical Forum area at ElectriciansForums.net
