Search for tools and product advice,
Discuss fitting a pir near roadside in the UK Electrical Forum area at ElectriciansForums.net
multimick
got a job fitting a pir near side of road (4 metres away) to contol 2 led floods any tips to avoid cars or pushbikes setting it off ,i can point it down and buy one with sensitivity control but any other tips please
The timeguard make, gives opaque stickers that you use to shield that aspect of the PIR sensor - you should be able to do the same if picking up motion below the light and around. Might have to do walk test a few times to get it right.
PIRs detect heat not motion. At least that's the case with alarm systems that I've worked on. You should be able to adjust the range to its minimum and point them down. Just need to work it out.
Generally a PIR sensor has the top half as long range and the bottom half as short range so blocking off long range should help. I often use good quality waterproof tape to block sections if not using the ones Rpa07 mentions.
PIR motion detectors detect the movement of heat...….hence they are motion detectors. In other words, detecting both. Stand perfectly still and no operation.
Yes. That's true. If the heat source happens to be moving. But the fact that the heat source might be moving is irrelevant. If the moving object is at ambient temperature then a basic PIR won't detect it. They are heat sensors. For example, if someone throws a rock through a window a standard PIR won't detect it. That's why Honeywell, for example, provide Dual Tec sensors. They use both passive infra red, to detect heat sources, and microwave technology to detect moving objects that don't have a heat fingerprint.
:confused:What's all that got to do with it?
A PIR motion sensor takes a moving heat source to operate.
I know it's off topic but just clarifying my first comment which you challenged. Here is a picture of a brick. It was thrown through a window. The PIR is just above my head when I took this picture. It did not trigger and it was functional. I tested it afterwards. I replaced all PIRs with Dual Tec.
It would've triggered if they'd jumped through the window after smashing it, though.....:rolleyes:
Exactly. That's my point. It takes a heat signature to activate it. They are not motion sensors. They are heat sensors. You could place a lamp in front of a PIR and drag it about. It will not trigger. Leave it where it is and just switch it on and the heat from the bulb will trigger it. Try it.
As far as I understand it, a PIR sensor has a spread of sections that are sensitive to heat, generally approximately human body temperature, though any wide range of heat source will work and the received light is focused onto the section.
Each section is looking for a change in heat reception, i.e. a presence or absence of heat, if this change occurs from one section to another, or repeatedly on one section, depending on the algorithm used by the manufacturer, then the PIR will trigger an output.
A moving incandescent lamp should trigger a PIR as it will be sending out a wide range of IR wavelengths, similarly if the lamp is switched on the detecting section will register a change in temperature as the lamp heats up from cold and as it passes the temperature range and so will also trigger.
You silly sausage, the leaves grow back in the Spring. Watch a bit more Gardeners World, you'll get there.
but the beer in my glass won't grow back. i have to go to the offy. maybe i should plant a beer tree in a barrel.
Reply to fitting a pir near roadside in the UK Electrical Forum area at ElectriciansForums.net
Hi we are replacing light fittings in our home. Im confident with the fitting aspect, but have run into doubt in making the right choice of...
Hello fellow sparks, I’ve decided to go out on my own. Recently bought a little van and trying to get myself set up whilst keeping my costs as...
I’ve been asked to price up a job which includes fitting a 100watt led flood on top of a 6m pole. Thinking of using a lamp post with a...
