Dot and dab is a quick way to refurb old buildings whose render coat has lost adhesion...used a lot down here on old terrace buildings...never gonna be 35 mm though, cost alone would prevent it, done properly it would finish as per the original inch ish 25 mm render and plaster finish,personally I’d put 35 mm boxes in but sometimes as per the op there’s a tight window.....but don’t forget depending on age of building, you may not even get the 25 mm you need in some areas!
Dot and dab or any type of finish should not be used on top of blown render, it should all be hacked off and then you can hard plaster.
Reactions: nicebutdim
You don't dot and dap on ceilings, I thought that would be understood and did not need explaining, perhaps you are too young to remember the traditional way of constructing domestic buildings.
Ha I miss read your post , you said plasterboard only.
If a kitchen fitter can't trim down a unit to fit the space he's not a "fitter" at all. They are adept at putting in "filler" boards to make up a gap of a few inches, and clearly prefer to do that rather than trim a larger unit to fit.
  • Dislike
Reactions: UNG
Well everyone else miss reads the post's so why not you as well, we seem to need the minutiae in all explanations or someone will come back with a question that should be a given.
you mean lath and plaster with half a horse's hair in the plaster, or straw walls?
I'm too young too Mike... like this you mean ?
  • Funny
Reactions: Baddegg
Call me old fashioned, but IMO plasterboard should only be used on ceilings, dot and dab was invented to speed up construction no other reason, any muppet can do it, very little skill involved, with hard plaster, cupboards and fittings can be fitted directly to the wall no need for noggins, but it does need skill which seems to be lacking in the building trade these days.
Dot and dab was introduced in an attempt to increase the insulation value of walls.
For a decent plasterer dot and dab is no quicker than bond and skim
Trimming a cupboard is the easy bit it's trimming the doors that generally causes the problems
Although I do know a couple of companies that will build kitchen cupboards and doors to customer sizes which does solve a lot of space problems
In most instances it would be more expensive to resize doors (if at all possible), than to dump them and fit new. Regardless, someone would have to pay for any modifcations and it would be a rather extreme solution to the problem of the spark not wanting to chase 35mm boxes.
Absolute not, dot and dab was only introduced to speed up construction for mass produced domestic building no waiting for drying periods when a three layer plaster construction was normal to plaster a house, there is no thermal advantage to plasterboard unless it has a insulation layer in its construction, in which case a 35mm box would fit behind it, dot and dab is completed in one day, traditional plastered walls takes three days, plus a drying period, don't know if you have ever worked on any sites, but you obviously have not seen traditional plastering done correctly.
[automerge]1598041073[/automerge]
Not straw wall, but cob walls. ;)
Reactions: Simon47
Occasionally I've seen old houses where walls have been battened and boarded, but that was a cheap fix over rough walls. When such old houses are refurbished, those walls are picked bare and floated out in plaster.
The whole idea of dot and dab is alien to me and I really struggle to understand why someone would want to finish a solid wall in this way. Is there a significant saving per sq meter on finished walls and does dot and dab impact on sale value of houses?
Most punters now days do not know the difference between dot and dab and traditional wall plastering, its only used in this modern age in very high end domestic building, the last one I was involved with at 67million had to import the plasterers from Poland to get the finish they required, the saving is in the time it takes to do a good job, as I said dot and dab in a day traditional takes many days.
They could have contracted plasterers from NI as this is how they finish walls every day of the week.
Reactions: 123
One of the walls in the mansion was over 20M long and looking from one end there was not a fault or flaw to be seen, craftsmanship at its highest, mind you the electrics left a lot to be desired, but these high end domestic buildings only have a life expectancy of 10:20 years.
Sample of their work: HARRISON VARMA - Recherche Google - https://www.google.com/search?rlz=1C5CHFA_enGB718GB718&sxsrf=ALeKk02OePxRYbN7kVapUq7v5qfq4uYb5Q:1598043022929&source=univ&tbm=isch&q=HARRISON+VARMA&sa=X&ved=2ahUKEwjQsN6Vlq3rAhWCiVwKHaWqAuQQjJkEegQICRAB&biw=1268&bih=619
Dot & Dab can get you out of a whole host of problems with houses built in the 50/s 60's, especially when existing walls are unlevel, cracked and contain different finishes like multi finish, fillers and cement, as well as umpteen coats of different paints. All of which cause bubbling, cracking and different drying times when plastering over, unless of course you strip it back to bare walls which takes forever cuz most of the base coats are strong mortars!
Saying that Browning is just as bad to strip back as well.
On solid brick walls though then best to lime plaster it so it can breathe!
Reactions: swaRRR
where was this then mike?....I could phone 5 British plasterers now who could do it, don’t believe the hype it’s about the cost of the tradesmen not a skills shortage....
Look two post above, and I can assure you it's about the skill not the cost.
Hah you have been reading too many blogs on Facebook re French building, walls do not breathe they allow water vapour to pass, in the UK we have more water vapour outside our buildings than inside, but we don't get many solid brick walls since the victorian times, in 1954 when the building regulations first came out cavity wall construction became the normally accepted construction method and the introduction of two coats of Browning and finish became the norm and if you ever saw how much interstitial condensation happens on the inside of a cavity wall you would not question its permeability.
[automerge]1598044070[/automerge]
Looked at it? Not seeing anything a British spread couldn’t do...
If they are that good then I doubt they are available. :yum:
JLeague
Huddersfield
Dot Dab Plaster wall - 35mm box? Plasterer at odds with electrician
JLeague,
Mike Johnson,
