Discuss Is loose trunking C2 or C3 in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Car123
I had an EICR done in 2014. Some loose trunking on a wire to the showers self isolator based on the wall was graded C3. In an EICR done this week the same trunking in the same condition was graded C2. This seems a bit over the top please advise
What do you mean by loose trunking? Is it not secured to the wall? If not then can you just glue it?
I expect you can just glue it. I rent the house. But the electrician is quoting for work as a C2 and my question is whether it should be graded C2 or C3
Doesn't matter what code, just get it secured. Take less time than finding out what the code should be!
Well I don't argue with that. But nonetheless I would like some advice about this coding. The trunking is not hanging off its just not attached solidly to the wall. By grading it C2 the electrician does not pass the EICR and I have to pay him to come back. I am looking for guidelines on this grading
There was a change in the 18th edition, associated with premature collapse of wiring, under this all cables must be properly secured with fire resistant fittings (or other physical means), if this is not present, then it's a C2.
Just gluing it will not satisfy the regs.
Would that only apply to a new installation ?
Sounds like you need it fixed with something that is heat-proof like a metal clip / stainless cable tie, etc. Any photos possible so folk here can suggest solutions?
If you are quoted under £50 to fix it probably simpler and easier to just get it done, as often buying a box of 100 clips, etc, will be the best part of that anyway.
True, but realistically it may just be a short length of cable above the bath in the corner of the bathroom. Never going to cause an issue with access.
I rent a house out and take good care of it. Not all landlords are bad.
Completely understand that mate, I’ve rented in the past just curious as to why so concerned....I’m with you for a decent landlord idve just stuck down and if I liked the client idve made good of whilst doing the EICR so it was never an issue ?
The BPG#4 has this under C3:
  • Wiring systems not adequately supported to prevent premature collapse in the event of a fire. Note: In locations other than in individual dwellings, such as communal areas forming part of an escape route, this would warrant a code C2 classification to be recorded)
The clarification is a bit convoluted to me, as it sounds like C2 only non-domestic but I think they mean (or maybe they should mean) C2 for any escape route or likely fireman access route.
Seems sensible. A code of C2 force cable in the corner of the bathroom seems harsh.
Mind you, we haven't seen a photo yet have we?
Bit of engineering judgement here surely...it’s been there years and isn’t in an escape route of any kind...c3 at worst surely? And it complies at the time of installation...
Now that these EICRs have become mandatory none of the people doing them are doing any work at the time. Well not where my house is. So it seems to me a great money spinner. If it was done at the time it would be simplet
I am not there as I live elsewhere. 350 miles away. The cable is in the kitchen on adjoining wall. Fridge freezer is about a food away
Some of us are doing minor remedial works at the time, by prior agreement, as it saves the landlord time & money. Likely fixing a piece of trunking would fall into that category. However, there are some landlords who want a quote beforehand for everything however minor - those I am not fixing at the time, and it will eventually cost them more.
Well common sense tells me that. Believe me I have done everything to make the place safe including work that is not mandatory. For example a wired fire alarm system. It's not a house of multiple occupation. I have put in new lights, lots of points etc
I would most certainly have been happy for the work at the time. I feel that I am being ripped off to be far. And I have used them before to do lots of things
The 'escape route' part has been changed. It now applies to all wiring.
Yep...I was getting at the fact it didn’t when installed mate, don’t get wrong if that was in an escape route I’d c2 it but it’s a bit harsh considering it’s location
As @DPG commented in post #20, I haven't seen any pics of the trunking so it's hard to say mate.
Well I find it ridiculous actually. It's secure it has not moved
As I explained as I am not there I can't photo it I am 350 miles away
Very true mate
I cannot photo it as I am not there
Pay a local handyman to secure it. Shouldn't cost much. Pop the cable out, couple of holes drilled, pop cable back in. It would be good for you to find a local tradesman who you can use for jobs like this.
I’ve actually taken someone on now as an arm of my business as handy man stuff becomes much more a thing with the current generation....
Just to add to the above, if you do this then get them to use fireproof cable clips & get them to take pics and send to you. You can then send them to the electrician.
Top advice. Indeed.
We love a picture....it makes the whole thing a more immersive experience for us......for the love of good don’t put cheesecake in it though!....it’ll go wrong
Cheesecake may be good for fireproofing... Not that there is ever any left for me to test this out...
Problem is that in order to get the EICR signed off they say they would need to come back and do further testing once work is done. I am in a catch 22 situation with them
Testing of what?.....that repair is a visual confirmation....what does the landlord think of this?....
I'd ask the electrician what 'tests' are they are going to do with the trunking, if the only thing wrong is that it is 'loose'??
Bugger... @Baddegg beat me to it....
Complying at the time of installation is irrelevant. That said, if it is not fixed to the wall then it wouldn't ever have complied.
You can send all the photos you want to the Electrician, but they won't certify the work you have done nor would they alter a report which has been issued. I certainly wouldn't.
Reply to Is loose trunking C2 or C3 in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Good morning, We have a two-bedroom flat that my wife and I rent out to supplement our income. Following the recent EICR, several issues...
Hi everyone Ive just had an electrical condition report conducted on a mixed-use property, and I am extremely surprised that after the last report...
Hi, I have a property that I was looking to rent out. Its 12 years old property so relatively new. I had a EICR done from a qualified electrican...
7K
Hello. Non-electrician here. Failed an EICR yesterday as the electrician graded my consumer unit C2. Why C2 and not C3? He didn't say (and still...
I'm practising EICRs on friendly locations as I'm still in training - technically done my 2391-52 but frankly need loads more practise. I've just...
