Discuss Rough quote? in the UK Electrical Forum area at ElectriciansForums.net
Hi folks, I’ve been asked to change some accessories and I’ve no clue what to charge, just wondering if anybody could give me a rough quote? All the accessories are flat plate and screwless but it’s on freshly plastered walls.
The accessories to change are;
17 x twin sockets
2 x switched fused spurs
4 x 1 gang light switches
2 x 1 gang dimmer switches
2 x 2 gang light switches
1 x BT point
Im not interested in taking into account mileage/fuel etc, just for the labour. Also customer is supplying accessories.
Thanks in advance guys.
Seriously? I wasn’t expecting to charge that sort of cost tbh, perhaps showing my lack of experience in doing jobs for myself. Have you calculated that on a per point value then?
Even if the plaster looks OK, you could be in for a hard shift if it is not.
Best to cover yourself . It is easier to come down than up.
So what were you thinking of charging, flat plate screwless accessories can be a nightmare to fit and get them looking right, assuming 15 minutes per point it's 7 hours work before you do any testing
£240 would be my quote with the proviso that extra costs would be added if any back boxes had to be exchanged for deeper ones.
Or...
send the apprentice in for the day , give him (or her) their normal pay say £50 for the day , charge the customer £250 which is a fair price.
thats £200 in your pocket for Christmas beer And wine :)
Day rate for me.
You have to allow the full day for the job in the diary so unless there is an as and when job nearby the rest of the day is dead time.
I would charge a call out fee to start with and check the back boxes Then if all good to go after a sample few Charge A my day rate less call out fee if agreed to proceed.
For me, this totals up to a full day, and £280 on a day rate.
Yes it might be done a bit quicker, but when you find several of the sockets are USB and don't quite fit the boxes, oh and the dimmers have to fit into 16mm back boxes, it may well take longer than you think.
could always fit surface pattresses over the existing back boxes. (said with builder's hard hat and hi-viz underpants on).
If everything is ok and no nasty surprises await you, it's a days work. So charge a day's work at whatever your day rate is. For me it would be something in the region of £300.
That's expensive for someone who will have to get a qualified electrician to sign off their work, their cost will have to be added.
It's your delusions that are the problem, from someone with no qualifications you deem you are able to give people advise, you may well be able to converse in French better than I, but to use that to score points is really taking the proverbial on a UK Forum.
I did a job like this just over a year ago, 40 plates altogether: 2G skts, 1G/2G light switches, SFCUs/FCUs and a couple of shaver sockets. Not flat plate, but low profile decorative. Took me 7 hours; charged for a bag of pattress screw extenders and replaced a fast fix box. Client inspected every one. I was relatively lucky as the existing cables had been nicely (professionally) dressed, and the locations of most of the terminals wasn't too far out from the old fittings.
Still one of the dullest, most tedious days of my working life so far. It just seemed to take forever.
17 x twin sockets
1 x BT point
All I can add to this be careful because you never know what you are going to run into. I would say 2 days so you won’t be rushed and miss something. Good luck with your project
'Delusions'? What delusions? Saying what I would charge if i were doing the job as a qualified person?
Am i allowed to say what the price would be on average even though i'm not qualified?
Or you mean consistently putting you right on the parts of French legislation that you clearly don't understand properly? Like i said, you seem salty and to come in waving the 'you're not even qualified' flag and specifically mentioning signing off non-notifiable work without contributing anything else to the thread was your attempt at a cheap shot, trying to put me down for not being in your club. It was pretty pathetic and uncalled for to be honest, and just shows how petty you are. I dunno, maybe you have a thing about being wrong about notifiable work since you appear to not know the rules on either side of the channel. So much for being qualified. And to then try to bring up me mentioning things as point scoring when i was happily minding my own business in this thread is laughable.
Yes, I'm not qualified...yet. I'm a trainee. And everyone here knows it. Yet you tried to put down a trainee on a public forum to make yourself feel better. Very sad. Your comment is water off a duck's back.
17 x twin sockets
1 x BT point
Would have been nice if you said in this thread what price you thought as well TBH, Lets hope you looked at the existing wiring first to make sure there are CPCs in the cabling and the DB is not 50 years old
He mentioned in the original post it had been rewired and re plastered
The original post mentions "freshly plastered walls" but I'm not seeing rewiring actually stated - it may be, or that may just be wishful thinking. He does mention "flat plate" so lets also hope the plastering is good, with no bumps and dips, or the flat plates might start popping off.
Oh yea your right, no idea where I got that from then ??‍♂️
Post #6 mentions it being rewired recently
Reply to Rough quote? in the UK Electrical Forum area at ElectriciansForums.net
I am trying to understand how a relay system works and have designed a circuit and a ladder diagram all as attached for an 8 PIN relay, a current...
Hi all, I am a new home owner and have had a quote on some electrical work I wanted done in my home. I was wondering on if someone could give...
I currently have 2 ceiling lights in my living room that I wish to replace with 2 Phillips Hue lights. The current lights are turned on and off...
Morning All I recently completed my first re wire and board change, (with help from the owner who is a gas fitter and plumper, who works with my...
Hi guys. Been asked to change a load of accessories in a house. I’ve done an inspection and the wiring is tidy, Hager CU, all circuits protected...
5K
