Discuss No bonding, no work getting carried out? in the UK Electrical Forum area at ElectriciansForums.net
IAmSparkytus!
Evening all,
My NIC inspector told me years ago "if there is no bonding in place, you're within your rights to switch off the electrical installation until works have been carried out!".... not sure if this is true?
When asked by a customer to carry out a job which you give a cost for before going to look at the works, whats your procedure if when you get to site there is no bonding where required?
Do you knock the juice off? Do you provide a quote to install bonding before carrying out any further works (this has been my go to)? Do you carry out the requested works and then advise and quote?
You have absolutely no right to isolate someone's electrics. Top tip whatever a scheme inspector advises you to do, do the opposite.
About 15 years I heard an Niceic inspector tell an sparks to bond an aluminium door frame (no I’m not joking) as it was within close proximity of the meter cupboard and someone could touch the door frame while touching the meter…
What about old 6mm bonding ?
I think my parents house still has 6mm to the gas (I added 10mm to the water when I changed the board about 12 years ago)
There's a lot of variables when you enter an unknown installation ,some more important than others depending on the type of job you're doing assuming you don't know what the condition of of the installation is
If you're handed a verifiable piece of official paper proving that everything is in order and the installation is 100% safe well then you're safe to proceed with work subject to the usual caveats of upgrading the installation to take into consideration the new work
Reply to No bonding, no work getting carried out? in the UK Electrical Forum area at ElectriciansForums.net
No waffling, going to get straight to the point. Main water on the exterior of the building in plastic. Changes to copper inside the building...
Seeking advice, we have been replacing extractor fans for a local council and was originally told no ‘like for like’ replacement works needs a...
Doing a kitchen job for my daughter’s music teacher, who also happens to have been in my wife’s class at school. Nothing big… just a little...
Hi, I am just wondering if there is anybody out there interested in allowing me to do a little voluntary work with your company to gain a little...
Hi everyone just looking for some advice before buying stuff not planning on carrying out this work myself will get someone who knows what their...
