Discuss Immersion heater wiring in the UK Electrical Forum area at ElectriciansForums.net
I've recently moved into a house and would like to check please whether an immersion heater that looks recently fitted has been correctly wired.
It's rated at 3Kw and is wired with 2.5mm2 cable from a 16a MCB. The isolator switch is embossed 'immersion heater' and matches the images of 20a double-pole immersion heater isolation switches I've seen online.
Does that look ok?
Many thanks.
Reply to Immersion heater wiring in the UK Electrical Forum area at ElectriciansForums.net
Until last week I had a dual tariff electricity supply with a cheaper overnight tariff. This was good for the storage heating, but now the storage...
I've a 3 phase storage heater currently wired to the main fuse box in an office I have. The heater has 2 supplies/isolators, 1 for charging at...
Hi, I know it's best practice to run an immersion on a dedicated circuit but am I OK with the following A new heat pump is being fitted and it...
Hello all.. I have been asked to wire a relay into a FCU for a 3kW immersion. The plan is for the customer to be able to access the immersion...
Been round to a house to quote to replace some storage heaters for new panel heaters and came across a strange (to me at least) way of wiring the...
4K
