C
Callcom
I've recently moved into a house and would like to check please whether an immersion heater that looks recently fitted has been correctly wired.
It's rated at 3Kw and is wired with 2.5mm2 cable from a 16a MCB. The isolator switch is embossed 'immersion heater' and matches the images of 20a double-pole immersion heater isolation switches I've seen online.
Does that look ok?
Many thanks.
What is between the isolator switch and the immersion heater?
From your description of everything, that sounds fine for the materials used. They are what would be used for a 'normal' installation
Reactions: James and DPG
Immersion heater wiring
Callcom,
Callcom,
