- Dec 14, 2019
- 100
- 22
- 93
- United Kingdom
- Electrical Enthusiast (Unqualified Hobbyist etc)
Hi all Happy Christmas to you and yours.
I need some expert advice
I made the temporary leap to a off grid Mobile home a few months ago while I build my house.
All works ok, generator during the day and batteries and a 1 to 2 kw 220v inverter at night.
However, there is a slight problem, I am using an oil boiler out side for heat. Something is burning/melting a hole in the control panel? It's going on for months, don't think it's hot all the time bit can't be sure. Is the wiring wrong or what can be causing this? It's already killed one control panel. A worrying site to me. Possible problem s would be helpful. A newly qualified electrician did this install. Thank you all.
