Discuss pulling my fuse out nightmare in the UK Electrical Forum area at ElectriciansForums.net
S
s.keech
hi just contacted d.n.o about fitting isolator for a c.u. change for elecsa assessment in my own flat. They said get a registered spark to do the work. then I replied that I need isolator so I can do the work and register. They then said to register with elecsa and then do work. I cant register until I complete the work and can not do the work unless it is isolated. Am I just getting dizzy going round in circles or just pull fuse and do work. I have 2330 level 3 so classed as competent but are they? what do I do?
It looks to me as though you have made "best endeavors" to do things through the proper channels and have got nowhere.
If this was me, I would do a Risk Assessment - check the condition of the fuse holder etc. do I feel I'm competent enough to do this? then switch off the main switch at CU to take load off the fuse and just pull the bloody thing and get on with the job, but that's just me - an old retired bloke who's fed up to the back teeth with Jobsworths who won't do their jobs !!!
I find the DNO the most unhelpful people around. Had the missfortune of needing there help twice before both on EICR and both where there equipment is damaged..
if you are going to pull it yourself, just make sure you follow geordie's advice and make sure there's no load going through it. sorry if this sounds bleeding obvious.
by the way, having the level 3 2330 doesn't mean you're automatically classed as competent (i'm not saying you aren't competent - just that there's more to it than that).
good luck with the assessment.
What trouble could a (competant person/electrician) get into if you do break those seals and pull the fuse, if you were to get into any.
Pull the fuse(folowing given precautions)
Do the work
Refit fuse
Get assessment
Get registered
Contact DNO as a Registered Electrician to report the fuse has been pulled and needs resealing.
i'd hate to be a canadian spark. they deal with their seals with a club.
Ooops!
Hi, Geordie sparks post is spot on. I was in exactly the same position as you a few years ago for my assessment, i always wear electricians gloves with protectors and eye protection when pulling the fuse, just make sure you either, cover with tape when the fuse is out or remove fuse and replace carrier. I always reseal afterwards. Seals on ebay.
Cheers
Cheers
Spot on. Buy some off ebay. No one cares! Apathy rules.
there are houses that aren't sealed and haven't been for 39 years. No one cares.
there are houses that are sealed with seals off ebay, no one cares.
no one cares.
The only person that is important is you and your standards.
the only time someone will be interested is if theres a problem. And it affects their butt
no one cares.
- - - Updated - - -
no one cares.
And that, in a nutshell is it!! :)
in the old days the seals were made of lead they were easy to remove then replace each seal had a code from the crimp tool too
the dno were much more touchy about removing the seal
I really don't see what the issue is here. The DNO don't need to know, nor should they care whether you are a registered electrician or not. All they should do is install the isolator, end of.
Reply to pulling my fuse out nightmare in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Been browsing these forums for a while, always great to learn a new way to skin the same cat. Anyway, cut a long story short, was an...
An old and now deceased friend's place has some rewirable fuses with asbestos flash pads. They are long overdue for replacement and now that seems...
Completed my AM2s start of this year. My whole career plan is to run my own company/sole trader. Be my own boss basically. I always get asked...
As per normal I was in a rush and didn't get enough information. I was working in an apartment that didn't have any power and when I went to...
Hi everyone I’m new here and wanted to ask a question. I want to do some domestic jobs but are currently not registered with a body. I trained a...
