M
Why do you need a back box for the arm of you're sofa?
Most likely Appleby by the looks of it, but most LUGS can be made to fit.
There's no way you or anybody else is gonna start buggering aboot with MY lugs bonny lad!! :32:
So he can connect the cpc to it.
The latest EU directive says "All sofas shall be earthed - BY ORDER!!"
Grip the lug with a pair of pliers so you can deform the bolt hole to an oval shape, then force the bolt in causing it to cut a new thread.
Lug piercing.......Geordie Spark style :bigear:
If you really want yer lugs pierced, Tidyboiler's the lass to do it. She learned how to do it from her Pikey Grandma. :frown2:
Ta...but I'll give that one a miss....bad enough clearing the wax, don't fancy the rust.
Grip the lug with a pair of pliers so you can deform the bolt hole to an oval shape, then force the bolt in causing it to cut a new thread.[/QUOTE]
right
wrong....run a new thread in it with a 3.5mm tap...
Oh there's no rust ........ she heats the needle to red hot first ............. then spits on it .....
oh aye....whats his name?One of my customers routinely comes up behind me when bending down at sockets and says "you've got a nice tight ar$e - have you been working out?"
I hope he's gentle. I've never done That Sort Of Thing before. :/
this is it...he might think he`s safe on that island with captain pugwash....but word gets about you know...That's not what I've heard. :wink_smile:
