What about silver coloured plastic conduit lololololol You know you can get it in any RAL colour............................ Sorry............... Normal service will resume!
Yes but it's eye wateringly expensive though Archy and I'm not so sure if they're putting it in conduit just yet![]()
Especially amongst foreign untrained sparks.There's a lot of that ignorance still about Mick.
I bet it is, but when it becomes cost effective, that'll be the death knell for steel conduit.
No more Hilmores, just lads armed with hair dryers!![]()
only used white and black
If its made off by a PROPERLY trained sparks it will comply.It's not just the fact that the armour is good enough, there's the fact that fault current is unlikely to flow through the external cpc anyway due to the inductive coupling with the armour.
I did some conduit today................ Real conduit (20mm Steel)... looks the dogs.. It had a 90 bend and then I had to put a dog leg in because the bloody IT guy stuck is poxy T2 right in the way!
There was a period (and probably now) when firms ran an earth wire alongside the swa because they were ignorant and did not know that 99.9 + per cent of the time the armour complied.
So you install 5core for tp sub mains do you?
Why wouldn't you trust it? There's nothing wrong in using the armour as long as it's been correctly sized and the chances of it coming out of a gland are nil as long as it's been done correctly.
What are your thoughts on conduit or trunking as a cpc?
how the frack do you use plastic conduit as cpc?!
