There was a period (and probably now) when firms ran an earth wire alongside the swa because they were ignorant and did not know that 99.9 + per cent of the time the armour complied.
What about silver coloured plastic conduit lololololol You know you can get it in any RAL colour............................ Sorry............... Normal service will resume!
Yes but it's eye wateringly expensive though Archy and I'm not so sure if they're putting it in conduit just yet :)
I bet it is, but when it becomes cost effective, that'll be the death knell for steel conduit.
No more Hilmores, just lads armed with hair dryers! :-)
See this is why I don't normally post after visiting the fang farrier...trauma makes me talk nonsense (both mental and financial trauma.....the wallet is still in shock. I'm in the wrong business....get it wrong as a dentist...charge twice....must be the only career where you can get things wrong and still bill the client.....)
Revised plan - go along the lines of what dave suggested - shed is only staying temporarily till I can get the garage erected (10 or 12 feet x 20 feet) and its getting a 40amp supply in 6mm2 3 Core SWA (recovered from the catenary supply I had at the last house, still in perfect nick so getting reused) buried under the gravelled drying area.
only used white and black
It's not just the fact that the armour is good enough, there's the fact that fault current is unlikely to flow through the external cpc anyway due to the inductive coupling with the armour.
I did some conduit today................ Real conduit (20mm Steel)... looks the dogs.. It had a 90 bend and then I had to put a dog leg in because the bloody IT guy stuck is poxy T2 right in the way!
- - - Updated - - -
Good buddy....... you stick with that... At least you won't get a belt off it!
overskilled
Mentor
Kirriemuir, Angus, DD8
Shed supply
Thread Tags
overskilled,
Bobster,
