Discuss Refused Connection in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Had my first refusal today for 50 KW system due to western power primary sub station not able to with stand all the Solar PV in the area.
I have to wait for the upgrades in a few months.
To much reverse power anyone else experience this yet
Not yet, didn't you get it connected within the written agreement timescales? I was always under the impression you didn't get an accept unless the upgrade work had been completed and no other connections were allowed until your offer had expired.
Ahhhh that's good, had plenty of them currently sitting on a £65k upgrade for 24kwp - 1.7kwp system x 20 and the client has agreed to pay
Yep had one refused in Leciestershire not so long ago (200kWp) got around it when we agreed not to export >3.68kW per phase :)
We estimated the total cost to the business based on matching their half hourly consumption data to half hourly generation data predictions was less than 4% so the project was still a goer :)
We've had 30kw turned down in devon as it's not far from a multi-acre solar farm. Have been told by WPD that Devon and Cornwall is 'full'. Unlikely to be any private upgrades that will fix it, they reckon it will take billions in infrastructure upgrades.
The solution would be to encourage some heavy (power consuming) industry into the area.
What make and type did you use to limit current capacity
we use power one with the PMU unit to control it, and elios 3 phase unit for the actual export limitation... it works, but waiting for a firmware upgrade to actually lock the setting.
currently only does up to 100A supplies though due to the CT clamps, another thing on my list to get sorted....... (looks at Andy Sibert)
The idea would be to switch of each individual inverter relative to output current but keeping in the DNO limit of export. Also would be good idea to rotate inverters to keep same number of hours usage.
Speak to Andy he can put you in touch with the G59 Panel manufacturers, works excatly that way, drops out the inverters one by one to keep below the value.
That's the advantage of multiple string inverters of a central one :)
Of course it would be nice if they could monitor them all, look at the generation. load and limits and choose which one to drop next , that would be too clever!! Instead at this point in time you'll have to choose in advance and set the order up based on your knowledge of their likely load levels and typical generation - hence our half hourly analysis - only took about 8 hours to do.
FYI, 4-Noks are going to port across a similar system to the Elios PRO that they use in mainland Europe that allows export management for up to 200kW (maybe 250kW) systems, with security/lockout of parameters. It's an available solution but just not yet configured for the UK market. Would be handy to have an idea of potential demand though, although I know personally of multiple situations where this is required, and will probably be more frequently required as the grid gets more and more saturated.
The electromechanical solution that Worcester refers to is a valid option that is almost 100% fail safe but it's primitive in that it switches off inverter(s) completely. Most modern European manufactured inverters have a facility to throttle their output to a preset % of peak power, in several steps - something that the German/Italian/Spanish grid operators do remotely if required (or managed by 3rd parties according to grid demand etc). We have somewhat different challenges over here to facilitate this kind of control but a closed loop feedback system using something like the P1 (ABB) PMU that Gavin is using, along with an export energy monitor like the Elios can provide a decent granularity of control compared to actually switching inverters off.
bagsy
The UK is going to be the biggest market in europe for this scale of installation, in coming years, and export limiting is going to be vital to this development, so the market potential is at least as big as any of their existing markets.
Not sure what it is with EU manufacturers not actually sussing this stuff out tbh, we're a top 5 global solar country, they need to start treating us as such, not like some sort of naughty child that they might give a few crumbs to if mainland Europe leaves anything for us.
So if I wanted solar as every one in my street had it, you might not be able to do it as there is already enough going into the grid ?
we'd only be able to install 16 amps per phase, and even then there's a risk of inverters tripping out due to the grid voltage being pushed out of range. It's going to become much more of an issue very rapidly in the next few years as we start maxing out the existing grid capacity with very dumb controls.
We've now hit the half way point to the 10GWp the grid reckons is the maximum sustainable without any form of smarter control of inverters etc.
Unfortunately nobody has done anything about smarter control of inverters, completely ignoring the lessons from Germany where they've had smart grid control of inverters for several years using the exact same inverters we're installing, presumably because nobody in power has much of a clue about this stuff - I know when we raised this at the G83/2 discussions, it caught OFgem and the DNOs on the hop as they'd no idea what was actually possible. At the time it was suggested this could come in with G83/3 in a few years, but they seriously understimated the speed the industry would be installing at, so in the meantime we've hit half their stated limit while they fiddle with other stuff.
Problem being, the greater the level of uncontrolled inverters we install now, the higher the level of restrictions that will end up being placed on smart controlled inverters later on, which is pretty silly really, and could end up restricting the total level possible to a lot lower than would be the case if we'd started with smart control from 1GWp onwards rather than waiting until we hit 10GWp.
[dismounts from soap box]
My area has not a lot of capacity left. Solar farms are popping up all over. The cereal farmers can make more money from renting land then actually farming it.
the clever ones are having the panels raised above ground and animals below.
they get more income from the same land then
no problem with pasture land (particularly as much of that has been left fallow anyway with reduction in cattle herds), but prime arable land should be used for growing crops, not solar, not grazing.
Something's gone wrong at a policy level if this is happening on a large scale.
Reply to Refused Connection in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Greetings, everyone, After dedicating over a month to researching Solar PV systems, I'm nearly ready to make a decision. I owe my progress to...
I have a client on a Superdeal tariff from SSE, the Superdeal Meter has 3 sets of tails coming out of it feeding 3 DBs: (i) DB1 - the main board...
I'm having an extension built and the builder leading the project has said that the electrician will be over in about 4-6 weeks to start his works...
So, I already have solar (an older FITS installation) and it's been particularly successful so I want to extend this. I'd like to do two things at...
Renewable energy startup is seeking a Technical Co-Founder to help create a company that is both socially and financially rewarding. The...
