Discuss C2 for extension lead on washing machine in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
If you create your own, you can have in it whatever you like. - Maybe call you book 'customer-wallet-breaker'Can somebody tell me which codebreakers book I find extension leads coded as a C2??
Fixed that for youYou can find me on U tube and I've beenqualifiedregistered as competent for 2 wholeyearsminutes. ?????
Very good is this available from NAPIT
Might as well be. Remember all these code break books regardless who produce them are based on opinions. Its your signature on these certs and so your neck on the block if anything hits the fan. Thats why these books annoy me. Your all out there doing your best, but not one so called governing body will stand by you or any of these books. There for guidance only !! Now we will climb back under our stones.Very good is this available from NAPIT
Be that as it may, the landlord now has an unsatisfactory report, and some legal 28-day clocks have started ticking.The EICR is for the fixed installation wiring, so this is out of scope as well as being a bit silly on his part.
Reply to C2 for extension lead on washing machine in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
