Discuss 2nd fixing should but oh no..... in the UK Electrical Forum area at ElectriciansForums.net
cliffed
Supporter
Anyone had problems with these slimline fittings,they are so slim,I just can’t get my head round it.
They are not fitting correctly to the wall,looks like these walls need to be flat,not happy with them at all .
usually you need a 35mm back box and a perfectly flat wall surface.
Obviously it’s all my fault they look crap,mention flat surfaces,to the guys on site,they think your taking the proverbial Mickey
If you sign up to the schneider trade page, they send you a drinks bottle, t shirt and you can get a 1 gang switch from the same range as a free sample. It is worth several quid so you may one day find a use for it! have to say i was not impressed, you have to push little plastic bits in to take the front face off to then install the 2 screws, the faceplate then clicks back on. but try removing it if its already installed! I wouldnt recommend them to customers... avoid them where possible.
I don't have a problem with them really - like has already been said IF the walls are flat. To remove the front just poke a 3/4mm screwdriver in the slot on the side and twist and it pops off easily.
Much better than the click definite screwless range imo. But also pricier.
I don't think the free sample screwless switch is from the same range as the OP Gavin. The sample I got was a weird mocha brown colour and is much fatter in profile than that in the link in post #1.
For some reason I received two of the sample switches. Can't say I am likely to use them anytime soon due to their colour.
I bizarrely awhile back, let her indoors pick the faceplates for the new kitchen. She went for the slimline ones, little did I know. Even the 35mm back box were a struggle. Just recently had to move one; I swear the back box was 100% level, but couldn't get the faceplate level, the tolerances are tight. Food for the devil. Never ever again
Reply to 2nd fixing should but oh no..... in the UK Electrical Forum area at ElectriciansForums.net
I'm looking at a vending hot drinks machine 2.9kW that has a thermostatically controlled hot water tank permanently attached to a water supply...
I'm unsure if I should be an electrician or maybe another trade is better. I have basically completed my first year of a foundation in...
Just looking to see if anyone’s had a similar job or has any other ideas. Got a consumer unit to upgrade, the current one is fitted inside an...
Just had a simple kitchen light not working job, one of the fittings with the 4 spotlights on it. Took the fitting down to check if there was...
Evening all, Currently 1st fixing new extension however the existing cooker hood duct which was on outside wall will now be part of new utility...
