Discuss 2nd fixing should but oh no..... in the UK Electrical Forum area at ElectriciansForums.net
cliffed
Supporter
Anyone had problems with these slimline fittings,they are so slim,I just can’t get my head round it.
They are not fitting correctly to the wall,looks like these walls need to be flat,not happy with them at all .
usually you need a 35mm back box and a perfectly flat wall surface.
Obviously it’s all my fault they look crap,mention flat surfaces,to the guys on site,they think your taking the proverbial Mickey
If you sign up to the schneider trade page, they send you a drinks bottle, t shirt and you can get a 1 gang switch from the same range as a free sample. It is worth several quid so you may one day find a use for it! have to say i was not impressed, you have to push little plastic bits in to take the front face off to then install the 2 screws, the faceplate then clicks back on. but try removing it if its already installed! I wouldnt recommend them to customers... avoid them where possible.
I don't have a problem with them really - like has already been said IF the walls are flat. To remove the front just poke a 3/4mm screwdriver in the slot on the side and twist and it pops off easily.
Much better than the click definite screwless range imo. But also pricier.
I don't think the free sample screwless switch is from the same range as the OP Gavin. The sample I got was a weird mocha brown colour and is much fatter in profile than that in the link in post #1.
For some reason I received two of the sample switches. Can't say I am likely to use them anytime soon due to their colour.
I bizarrely awhile back, let her indoors pick the faceplates for the new kitchen. She went for the slimline ones, little did I know. Even the 35mm back box were a struggle. Just recently had to move one; I swear the back box was 100% level, but couldn't get the faceplate level, the tolerances are tight. Food for the devil. Never ever again
next time get a sample and see how much the back box needs too back in the wall ,possible to next door .:D try euro light next time .
I agree with NGD electrics. I use the ones which actually screw to the back box. Generally the faceplates in the OP's post work ok, but like everyone is saying if the wall is not flat (which can often be the case in an older property, farmhouse etc etc) then they can be impossible to get on properly.
3 steading conversions that the customer hired exclusively eastern europeans due to costs
not a single corner was 90*, more like around 80-100* corners, the roofs were also sloping (unintended), bits of the roof also sagged
the wiring was a joke, cables missing from switches, incomplete rings , every single switch must have been lowered aswell because every cable was jointed into connector blocks and singles taken from the connector into the switch backbox, no extra length on the cables either
cant comment on the plumbing works but i imagine they were much the same, so its not exclusive to older properties LOL
when nobody would sign it off he was obliged to get the pro's in, doubt he made any profit.
I have just finished a job that an electrician walked from that had the same brand. They look so bad. Sure the wall has to be flat and you do need a 35mm backbox, but even with that the finish is awful.
@Midwest in post #20 hit the nail on the head. There is so little movement you can do with these plates. Click Definity is the same.
I fitted out a kitchen with them once, never again. Laser level set the boxes through the lugs as normal, it took a good extra couple of hours to clean out the back boxes more than normal and still a total nightmare to get everything level and straight.
Also agree with @Leesparkykent that they look gash. For the extra money they cost and the extra work to install them I wouldn't have screwless flat plate near me. And standard screwed flat plate is even worse looking...it bends and bows and even on a nice flat wall you can see the silly gasket type thing the manufacturer has behind the plate.
I show click deco to customers and they generally all like it. Satin Chrome with black insert. I like how the switch modules are interchangeable and can add dimmer beside a switch in a 3G plate.
Those that don’t like black go for the grey BG Nexus range instead.
Out of all the flat plate stuff I’ve ever fitted, the Home Bargains stuff was by far the best to fit. Still looked like crap imo lol
its when youve got a dual box with 2x sw/fuses and the plates never sit flush with eachother without spending a lifetime to get them to sit right
Mods, why is my writing above below underlined and linking to Midwest's profile?
I'm confused.com...!
Reply to 2nd fixing should but oh no..... in the UK Electrical Forum area at ElectriciansForums.net
I'm looking at a vending hot drinks machine 2.9kW that has a thermostatically controlled hot water tank permanently attached to a water supply...
I'm unsure if I should be an electrician or maybe another trade is better. I have basically completed my first year of a foundation in...
Just looking to see if anyone’s had a similar job or has any other ideas. Got a consumer unit to upgrade, the current one is fitted inside an...
Just had a simple kitchen light not working job, one of the fittings with the 4 spotlights on it. Took the fitting down to check if there was...
Evening all, Currently 1st fixing new extension however the existing cooker hood duct which was on outside wall will now be part of new utility...
