Discuss 3 Phase cable, single phase single phase supply. in the UK Electrical Forum area at ElectriciansForums.net
P
Paulm0479
I need to use a 3 phase cable that is connected at the incoming end and supplies a 3 phase board that is to be removed.
My question is, is it ok to use the 3 phase incomer isolator but just remove 2 of the phases that feed it (black grey) and just use the brown and blue cores to supply the single phase board. Also what is good practice for the extra cores at both ends?
thanks.
Why are you removing the 3phase DB?
But yes you can. I'd like to see personally the spare cores marked up and connected to earth.
I'd leave the DB where it is, but that's as much as I'm saying as I don't know anything about the OP, and a question like this makes me more than a little dubious about dishing information.
Reply to 3 Phase cable, single phase single phase supply. in the UK Electrical Forum area at ElectriciansForums.net
I have a scenario where there is a three phase DB in a commercial property where there are mixture of three phase and single phase washing...
When there exists a single-phase transfer switch within a 3-phase distribution system, is it necessary for both feeds to the transfer switch to be...
Hi, searched the forum but cant locate anything similar so apologies if ive missed something. Ive got a new hob to install in the kitchen...
hi guys / girls , any advice would be appreciated, So the situation is a domestic property has a 3 phase supply , from the service head we have 3...
We are refurbishing an empty commercial building at the minute and I don't do commercial stuff day in day out so not entirely clued up on...
