Discuss 3 phase overhead power supply in the Australia area at ElectriciansForums.net
Hi folks I need some guidence on this. There's a 3phase overhead power supply feeding exterior accommadation at a hotel. What it seems they've done is taken the cable out at the chimney area at either end and then split the phases like you see on an electricity pole (wish I'd taken a pic). The owner wants me to run a new supply accross as the existing cable/wires look very worn to say the least. I was planning on supplying a 5 core 25mm swa and joining it at either side in the attic space and using a catenery wire to support it. The span is at least 40m. To me it's a very long for one span with only support at either end especially with a 25mm 5 core swa. The owner's not for going under ground at all so I'm kinda struggling a bit with this one. Any advice would be appreciated
Donny
Walk away, the cable weighs in at 93 kilos, thats going to require mega strong fixings into mega strong walls. Also how do you allow for the cable swinging around? I would tell them underground is the only way.
i agree. underground is the only viable option.
Donny
If your running this cable within the attic space, then why can't you cleat this cable in place, using a running board/cable tray or similar. Why on earth are you even thinking of running a catenary support wire in such a space??
think it is. i took his meannig to be that he was joining it in attics at either end of a 40m external run.
I've just re-read it and agree with tel! Nothing stopping him using bare conductors! Lol. I believe it's still acceptable in certain circumstances. Only he knows the job though.
step it up with a transformer to 11KV, use 2.5mm conductors, then step it down at other end.
I’d use 25mm hard drawn copper, double insulated 600/1100V grade. But I’m old fashioned. You need line taps and the insulated caps for them.
A set of chain blocks come in handy as well to tension the conductors.
The art comes in binding the conductors to the insulators.
Hence my original post, the equipment is available for hire, but would we forum users know of its existance? I would never use it, I would opt for buried anytime.
Most of what you have posted is for HV systems, and is not normally used for Lv, but never the less could be.
Not in this case he isn't. ....What he is saying is very true, there is an art or a knack to installing overhead wiring systems, be they catenary supported or self supported conductors...
there is no art or knack, its down to installation requirements and calculations.
I was a joiner for years before i decided to re train as an electrician, after qualifiying as a joiner I thought I could do anything until I became an electrician, now I know that I can do most things, but if I am stuck I can asj and get some answers.
Is there not?? Then i bow to your 4 years of Electrical installation knowledge, i've obviously been missing a good few details over the years.... Perhaps you can give the OP some further information about the permitted ''droop'' allowance and the tension calculation to afford those correct levels.
I just love listening to those, where everything is so easy to them!! lol!!!
Your aving a giraffe m8 !!!
Your from China - or so your profile says ?!
You seen the work they do out there ?
Someone dies get another from the paddy fields !!!
And your worried about a little bit of VD
(Thats Volt Drop by the way!!!)
Am i missing something here ?? Where did you read that i'm worried about ''volt drop''??
I may be working in China, but that doesn't mean i'm ''From'' China!!!
And No, ... i'm not having a giraffe as you call it!!!
It is common knowledge that the droop factor is not hard to work out.........it is infact directly proportional to the intake of bishops tipple, more that 3 and your drooping big style.
Having a giraffe surely you mean steffi graff.
Reply to 3 phase overhead power supply in the Australia area at ElectriciansForums.net
I have been asked to fit a 3 Phase 32 amp socket in a refrigerated area thats under construction. The cables will be on the walls and then a...
After my last post and having and having to re-learn some stuff can someone check and advise on a few things. Sorry if this is wrong don't hate...
Hi - first post, so I hope I get the tone right. I do pay professionals to do the work, but have a technical background and like to understand...
Hi All New member on this forum 1st post i need some good sound advice please I am a maintenance electrician and I have been asked to quote for a...
Hi, I am currently considering the best way to go about this job for a customer who wants garage power wiring from an overhead supply cable (to...
5K
