Snapester
Got a machine at a job rated at 32A Max, I believe that it will be fine on a 32amp commando interlocked socket but i have been requested to fit a 63amp?
Does anyone else think it should be overrated to 63amp, considering its backed at the board by a 32Amp opd.
It would be ok on a 32A but if you've been asked to fit a 63A then thats what needs fitting
The 63a is only the rating of the plug, if you are fused down at source, then no problems.
32A Commando Socket.
Snapester,
SirKit Breaker,
