Discuss 3p motor connection in the UK Electrical Forum area at ElectriciansForums.net
I would utilise a Star/Delta starter, if I was doing the installation.How would you connect this delta or star it’s got a 3p 400v supply,
Nameplate a bit confusing,I think.View attachment 57228
It does suggest that,links are horizonta,ie DeltaVery confusing, I would use star for 400 v based on the right hand diagram, both because of the diagram and because it makes sense (a 230v winding would have 230v if it was delta on 230v and star on 400v, the other way around just doesn't fit), and assume the rating text has the voltages transposed
Horizontal - as the right hand diagram, or vertical - as the left hand diagram?The high & low bit confusing to me,star is usually low & delta is high,on voltages.
The starters on site are Dol for that motor,not star delta,the links are horizontal,so presume a delta connettion.
[automerge]1586589262[/automerge]
Agree , got a bit confused on the high & low,Delta 230/400 v
Star 400/690.
The links are already fitted for Delta,which makes it a bit more confusing.
Star is the connection though
Yea the control will be 230v,I’ve only got limited info @ moment.
Sounds spot on about the motor, can it still be connected on the high V Star 3p.
Will also contact manufacturer,before connecttion
Thanks, the control system is 230v, there are lamps on the circuit.As far as the motor is concerned, yes a star connection should be correct for direct connection to 400v.
My concern is about the control circuits, the switches, lamps etc may only be rated for 240v - I assume the limit switches etc are well hidden within the equipment.
Yes by others DolIs the starter for the motor also included in the package or have you supplied it.
Assuming there is nothing in the control system which reduces your supply voltage to 230v then the links need changing.the links are vertical,thats the confusing part about it.
Reply to 3p motor connection in the UK Electrical Forum area at ElectriciansForums.net
