Discuss 4 gang 2 way 600 watt dimmer in the Australia area at ElectriciansForums.net
S
schoe
Does anyone no where I can get one from or if they exist. can you get them in a grid system which will fit in a 2 gang back box?
Thanks chris
I'm not sure of the terminology, are you trying to find a switch assy with 4 dimmers on the same gridplate?
Yeah sorry. I need either 4 dimmers on one switch capable of Switching 600 watts per dimmer.
Or a grid plate which will do the same, but will fit in a 2 gang back box. Hopefully that's a bit clearer.
Thanks for patiently clarifying. I don't know if the hardware exists but the heat load from four dimmers equalling 2.4kW in the same 2-gang back box will cause premature failure if it's not very well ventilated. Is there no way you can use tactile dimmers (4 wire modules) and mount them remote somewhere where there's more air movement?
The wires have already been run and tested. I have four circuits of spots in a kitchen. 2 circuits carry 450 watts one carries 600 watts and the fourth carries 250 watts. The customer ideally wants them all on one switch or on a grid plate. I've chopped a 2 gang box into the wall thinking I could fit all the dimmers in that using the grip plate. But from what your saying it doesn't seem possible so I'll just have to chop another back box in and have two 2 gang switches.
Thanks anyway
Chris
From what your saying this prob isn't
i ve seen the 4 wire onees,as somone said above, i have the same issue no doubt will be next week he be asking me again, i have 12 spots on one of my switches= 600 watts do these need to be rated at 1000W
Thanks anyway
Chris
A 600w dimmer for 600w of downlights wont last long.You need to up the size for downloights
Reply to 4 gang 2 way 600 watt dimmer in the Australia area at ElectriciansForums.net
Hi, in my bedroom i had a 2 gang dimmer that powered 2 set of 3 spot lights and also had passthrough wires to other sockets. Im changing to just...
This is confusing, I've ordered a few bits of this stuff, some switch modules and front plates and in the bumf on the website it says:- Click...
I really need help with this puzzler. First - I am moderately 'skilled' in day-to-day basic wiring. My puzzle: I am trying to replace a...
Hi all, I am upgrading my traditional 2 gang light switch in the kitchen to a smart 2 gang dimmer switch. When I wired up the switch the switch...
