Discuss 4kW now- addtional 4kw when approved by DNO in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
S
Somecamel
Really quick one- If I install 4kW for a customer now but have a DNO request in for 8kW, can I install the 4kW under 15.44 and later on the additional 4kW under 13.99p?
you should be able to, though I'd think you want to leave it a while before installing the 2nd system or someone might think you were pulling a fast one.
we've done it either side of a FIT change before now, and checked with Ofgem that is was definitely ok and got a yes, so installed 10kW then, another 20kW a couple of months later once we had G59 approval.
I do think it's a bit of a grey area though, and I'd say as a minimum you'd want to wait until the first fit application has been accepted and fully registered before even thinking about phase 2.
Reply to 4kW now- addtional 4kw when approved by DNO in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi guys, I've gotten AI to write up a terms and conditions for my company and then went through it with AI and tweaked it to make it sound a...
So far I have never had to deal with a new supply but a possible site we are looking at will need some major changes and so I wondered if folks...
This is quite lengthy so get comfy... I had a bizarre call out relating to a job I attended about five years ago. The situation was they were...
Hi, Small flat, currently has a small'ish feed water tank, top of a cupboard, feed through a wall into under stairs cupboard. Hot water tank...
I don't fit alarms as my main job but have fitted quite a few over the years whilst we were doing the electrics side of things. I usually fit the...
