Discuss Add a double dimer switch to an existing installation in the UK Electrical Forum area at ElectriciansForums.net
jimmydean
Hi,
Would like some advice please on the following issue.
2 (dimmable)wall lights which are plugged into a mains socket via a 5 amp fused plug. At the present time the two lamps are switched on and off by the plug socket. They are wired as follows. Lamp 1 is connected to the mains, and Lamp 2 is connected to Lamp 1, so both switch on and off together. The installed cable is 1.5mm twin & earth. Is it possible to introduce a double dimmer switch into the circuit ( would wall mount the switch) to control the lamps independently, and if so how would it be wired. The proposed double dimmer switch has L1, L2 and Common connection terminal( x2), with an earth terminal. Any help and advice will be greatly appreciated. Thank you
You can get dimmable 'in line' switches that attach to the cable to the light.
Doesn't sound like a very satisfactory set up but replace the t&e with a circular flex with the in line dimmer control and separate 13A (fused to 5A) plugs into separate socket outlets (or a twin adaptor).
If the dimmer is going between source of power and first light, then you’ll need a second switch wire from switch, jointed through at light 1 to go to light 2 (but not connected to light 1)
Would this be easier using dimmable smart bulbs in each fitting?
Thanks for the advice. I did this and added two smart dimmable bulbs. Thanks again
Reply to Add a double dimer switch to an existing installation in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm installing a Hoover oven and would like a little help please. The oven code is HOC3158IN. The oven manual states "The power cable must...
Hi, plumber here so please be gentle (or take the p-ss ;) ), I am supposed to be installing a UV water steriliser for a customer. I have some...
Evening Gents just after a bit of advice and what would you do differently. I have wired up 3 kw heaters in 4mm tuff cable (40 meter distance...
Hi. In the images. One is a 2 gang dimmer switch and the other a normal 2 gang switch arrangement. Dimmer 1 controls the main ceiling rose and...
Hi all, I am upgrading my traditional 2 gang light switch in the kitchen to a smart 2 gang dimmer switch. When I wired up the switch the switch...
