Discuss Adding more outside lights to same switch inside in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi. I have an outside porch light which has a switch just inside the hallway. I am adding 2 more outside lights to be switched on using that same switch. I have ran 1mm cable from the switch line and neutral & earth to the new light and continued that to the 2nd new light. When I switch the light on using the porch switch it comes on but it turns off after 5 seconds. Any help?
Are you sure you've connected to the switched live and neutral
Hi mate and welcome to the forum.
Temporarily wire the second (new) light to the first (existing) light. If it switches on and stays on, like the first light then that rules out the new light being faulty. You then that to look at the way you did your original wiring.
He's added 2 lights ,can't see both being faulty
Reply to Adding more outside lights to same switch inside in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi there, I have an outside light that is turned on with a switch from inside and would like to change it to a PIR version incorporating an...
I bought this house a couple months ago. It was built in 1952 (same as me) but has been rewired with yellow 12 awg Romex dated 2007. Looks like a...
Hi, Heavy industrial spark here, never do house bashing hence the question. I currently have a light switch at the front door not doing anything...
Hi, I have a single light switch, wired like this.. the 2 wires in com, with a always live wire coming to the switch, and then wire going out to...
Hi, New to the forum. I have two very specific questions, for the setup below. Setup details: Currently I have a setup with an outlet used for...
